How to remove threaded plugs - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-09-2012, 07:27 AM
Last journal entry: Still running strong
I want to remove the threaded plugs in the back of a Chevy 350 (oil galie plugs).Should I heat them up?There really in their tite,dont want to round off the head.
Old 08-09-2012, 07:45 AM
They're known as NPT (National Pipe Thread). It's a tapered thread so it's less likely to leak OR back out. Yes, TIGHT.
Use an acetyline torch (propane or butane is not "hot" enough). Heat the plug (NOT the block) until it glows. Allow it to "cool" just until the glow disappears. Hit it with some parafin (canning wax works really well). Use a 1/4" drive ratchet to remove them. If you get to them while they're still cooling (hot to the touch, so don't burn yourself), they'll come right out.
If for some reason, you DO "round" one, drill all the way though the plug with a 3/8" drill. Using a LARGE "EZ-Out", heat it again, hit it with the wax again and insert the EZ-Out and it should come out much easier.
BTW, they are "galleries", as in a shooting gallery or art gallery. A galley is a kitchen on a ship... (:-
Jim
Old 08-09-2012, 07:53 AM
The easiest, fastest way I have found is with a impact driver for use with a big hammer. You have to get the right square drive tool for the factory plug. I got mine from SnapOn 20+ years ago. Hit the driver with a 4lb hammer a few times and they will back right out.
Old 08-10-2012, 05:57 AM
Thanks,Ill do that.
Threaded oil gallery plugs on front of SBC CuttyGMachine Engine 5 10-30-2008 08:49 PM
Aren't these supposed to be threaded? 61bone Garage - Tools 2 07-29-2007 12:48 PM
Why not to remove spark plugs from hot aluminum heads? hotrodf1 Engine 13 09-14-2006 06:27 PM
Is it a bad idea to remove block drain plugs? 1ownerT Hotrodding Basics 9 08-24-2006 11:59 PM
non-threaded crank snout SBC4ME Engine 7 08-09-2005 09:18 PM
