How to remove transmission from 1953 Suburban
Today was a pretty good day
I removed my front clip, engine and wiring in preparation for the small block Chevy install and front power steering conversion. Everything went smooth, until I got to removing the manual transmission. How do I remove the transmission in a 1953 Chevy Suburban with the original transmission connected to a torque tube drive shaft Thanks for all the help.
Thanks for your help. I've never had any luck on the Stovebolt and couldn't stand the jokers. I find much better advice here at Hotrodders.
Try this
unbolt the rear springs and take the spring shackles off so the rear is free to slide back..then unbolt the torque tube from the rear of the tranny..slide the rear end back a bit and the tranny should come out..that should do it as I recall..
OMT |
stovebolt site can be a wild place at times.
if you have a torque tube drive line... to remove the tranny you must move the rear diff back as mentioned... ah the good ol days
At the Bonneville Salt Flats, first gear is known as 130 mph. |
I thank you all for your help. I had to leave town for business until Saturday. On Saturday I will loosen the spring shackles, roll the rearend back and remove the old transmission forever. Spoke to my wife on the phone last night, and was informed my CPP engine and transmission cross members arrived. I'm stoked as I'll be installing the engine and transmission this weekend
Well, I removed the front spring bolts, fully extended the jack stands and let the rearend down. I couldn't lift my truck high enough to get the rearend to drop or even slide the rearend back to remove the transmission. I pulled out the good ole cutting torch and removed the cross member and the transmission dropped. Guess I need to shell out the cash for a good over head lift. Thanks for the help.
| 1993 Suburban Transmission Swap | dlac1769 | Electrical | 1 | 10-30-2004 02:09 PM |
| 1993 Suburban k1500 Transmission upgrade | dlac1769 | Transmission - Rearend | 3 | 10-23-2004 07:26 AM |
| Transmission Information. | M&M CUSTOM | Transmission - Rearend | 1 | 08-24-2004 03:15 PM |
| 54 chevy ? | pichoboxing | Hotrodders' Lounge | 11 | 07-29-2002 06:32 PM |
| 92 chevy suburban 350 upgrade | ezthermal | Hotrodders' Lounge | 2 | 06-04-2002 06:22 PM |
