how remove valve spring & measure rate? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2011, 09:23 AM
001mustang's Avatar
I would like to remove valve spring from SBF and measure rate.
Any heads up for fairly inexpensive tools and procedure?
Old 02-06-2011, 09:42 AM
http://www.mytoolstore.com/kd/kdengi13.html
Scroll down to the bottom to see the KD tool that you can use
to remove valve springs without removing the head.
They're available most regular auto parts stores.
Just be sure to have the piston at the top of the cylinder
before you start to remove the spring, otherwise the
valve can drop down into the cylinder, no matter what
other method you may use, like these for example.
Some folks use a compressed air fitting to hold air pressure
in the cylinder to hold the valve in place.
I've also seen folks stuff a short length of cord or something
thru the spark plug hole (be sure to leave an end out! :-)
Or a stiff piece of wire bent so that it runs into the cylinder
and under the valve you're removing.
As far as measuring tension, unless you rig something up
using a common scale and somehow compress the spring against
it and measure height, I don't know.
Only thing I've seen used is a special use spring tension
measuring device that didn't look at all inexpensive.
Good luck!
Old 02-06-2011, 10:26 AM
001mustang's Avatar
thanks.
i forgot about the rope trick.
lol...leave end out...lol..have visions of facial expression one would make if end o rope feel in cylinder...lol
i have a shop press. maybe there is some kind of load sensor i could put between press ram and spring?
Old 02-07-2011, 04:59 AM
cal1320's Avatar
Try one of these with an arbor press or vice.
http://www.summitracing.com/parts/PRO-66834/
http://www.summitracing.com/parts/PRO-66835/
Old 02-07-2011, 09:09 AM
001mustang's Avatar
cool........
Old 02-07-2011, 03:16 PM
Silverback's Avatar
Boost Retard
Those work and are the right way to do it, but I have to admit that I've done the same using a bathroom scale, a board over the top of it to spread the load, the spring on the board and the whole deal in a press. Setup some sort of gauge to tell how much you're compressing it (I used a 1" travel dial gauge, but you could use a dial or digital caliper, or even a decent ruler to get you ballpark), 0 the scale to compensate for the weight of the board, compress it slightly to get a reading on the scale, measure or 0 the height, and then compress it to get a significant reading (the more into the range that the scale is intended to read, typically 100-300lbs the more accurate the final number will be), measure the travel and calculate the rate...
Old 02-07-2011, 03:46 PM
001mustang's Avatar
not as pretty but i don't see any reason why it wouldn't work pretty good.
i didn't think to attach dial to ram. good idea.
Old 02-07-2011, 04:53 PM
Silverback's Avatar
Boost Retard
it's not pretty, but it will work as well as you set it up. In my case I found that it was reproducible within about 1.5lbs/inch and within 2lbs of what the proper setup in the shop showed... good enough.
Those things are just cylinders with a known piston area and calibrated pressure gauge, they're easy to make if you have access to a lathe, the hardest part is finding a proper o-ring to fit your calculated piston size if you don't want to do any conversion. I keep meaning to make a couple of different size ones so I can measure how much force I'm putting on stuff in the press
Old 02-22-2011, 12:26 AM
001mustang's Avatar
Thanks awesome idea.
i cut some cards to 1.8", 1.77", 1.323" and 1.25".
preloaded scale w/ a 20lb weight and zeroed the scale.
took several measurements using press.
too easy
my calculated rate=308.6 lbs/inch.
COMP cam spring advertised rate is 308 lbs/inch.
how do i measure valve seat for valve head diameter? 406 ss monte Engine 2 04-07-2010 09:36 AM
Coil-Over Spring Rate J-Garden Suspension - Brakes - Steering 12 12-20-2009 12:45 AM
need to know coil spring rate runn141 Suspension - Brakes - Steering 2 11-27-2006 03:00 PM
spring rate? Blob Suspension - Brakes - Steering 7 02-04-2005 04:20 AM
Valve Spring Remove And Install Help! Angelshock23 Engine 9 09-27-2004 02:23 PM
