Well if that is not a good example of how knowledge of other trades can come in handy when working on your old hotrod.Pictures Pleeze R
"SlowRide66" "Illegitimis non carborundum" Don't let the bastards grind you down! Crankshaft Coalition Master List of Hotrodding Forums |
Here are a before and after pic. You can see dints and rust outs in the before pic. There is also a hole for the lic plate light lens. As this was no longer needed it was filled in with fiberglass/filler. My only concern is will the heat from the tail light bulb cause this repair any problems later on?
After they're painted on the inside with white semi-gloss paint, just add a small piece of chrome tape to the topside of the housing over top of the bulb. This will reflect heat and light off the surface.
I would like to see you put a step by step procedure of this in the Crankshaft Coalilition WiKi that is connected with this message board. That is excellent material that would help others. |
| GM courtesy lights | 78 monte | Electrical | 13 | 11-25-2009 05:48 PM |
| Having problems with the tail lights... | HammerGVette | Electrical | 3 | 04-17-2007 01:06 AM |
| voltage to tail lights vs brake lights? | stratt134 | Electrical | 12 | 06-10-2006 06:51 PM |
| Wiring Tail Lights & Turn Signals | horvath | Electrical | 15 | 04-30-2003 05:04 AM |
| Back Up Lights - how to choose? | horvath | Body - Exterior | 6 | 03-04-2003 03:20 PM |
