how to repair this damage - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-14-2008, 03:44 PM
GMR GMR is offline
This damage (deep scratches) is to front end of a 2004 Honda S2000. I think this is ABS plastic (it's not sheet metal). Probably caused by a parking space concrete barrier. How do I repair this?
Old 10-14-2008, 04:01 PM
Last journal entry: 50 Ply wagon
Since from the pic it is definitely gouged ,you will have to get a filler that's compatible with that plastic. I would check with your local paint supply place to see what you will need. But it can't be sanded and painted over, it's way to deep.
Old 10-14-2008, 10:00 PM
BMM BMM is offline
Sand with a buzzer 80 Grit. Determine if plastic is flexible or rigid (if it is really rigid, its ABS. Although, I would suspect its probably Polypropelene. Clean with plastic cleaner, apply adhesion promoter if neccesary. Apply fusor 114 (or equivalent, just what Id use). Prep to 180. Clean plastic again with soap and water, allow to dry. Apply adhesion promoter if neccesary, than 2-3 coats Primer surfacer.
If it is an Olefein, thats when you'd need an adhesion promoter (PP is).
Just whats Id do.
Old 10-15-2008, 01:00 PM
GMR GMR is offline
Thanks fellas, your replies helped a lot.
Fire damage repair Ricky Rocket Body - Exterior 1 11-05-2007 08:55 PM
Gel -Coat repair DV8 Body - Exterior 8 04-20-2007 09:15 PM
Intresting, maybe, new cars with the same exact damage......... MARTINSR Off-Topic 0 12-30-2006 01:20 PM
Dent Repair Randy Ferguson Body - Exterior 25 11-26-2005 09:00 PM
Rust damage repair oils65mustang Body - Exterior 1 04-14-2004 09:52 AM
