Just weld the holes up with your mig welder or wire welder. Start welding on the edge of the hole and just keep going in a circle untill the hole is closed up. , then grind down to suit.
Another trick that I learned was to use a Tig rod and put it in the hole, then spot it in with the Mig. It will fill the hole quicker, and the Tig rod will help "cool" the weld making it not burn through so easily-
Craig |
closeing up holes from burning through
NOCLONE you need a piece of copper [flatten copper tubing works great]
simply clamp copper behind hole ,and weld with mig on low. Copper will work as heat sink, and make weld flat on back. GOOD LUCK. |
If the holes are small enough, place a steel pop rivet in the hole, then weld it over. I have also used a small flat washer as a filler. Open the holes up just to the od of the small washer, insert washer to flush with surface, weld & finish.
| Welding info | Kevin45 | Body - Exterior | 10 | 08-26-2011 08:09 AM |
| "Basic of Basics" Welding - How do I repair body panels? | Centerline | Body - Exterior | 29 | 06-18-2009 06:54 AM |
| welder reccomendations? | rally4x4racer | Garage - Tools | 32 | 10-14-2008 09:00 PM |
| Welding Books | Magnus_Jager | General Rodding Tech | 6 | 11-29-2005 03:57 PM |
| welding repair roof line | camaroguy_1967 | Body - Exterior | 3 | 10-01-2003 07:34 PM |
