how to replace rear shocks - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-03-2011, 11:32 AM
JLBpontiac350's Avatar
85' grand prix,th200M,chev305
so i need to replace bolth rear shocks on my 85 grand prix. thare are co connceted to the frame. just need to know procedure. im assuming jack up the read end. remove the not and bolths from bolth side. push the sompress the rod so i can get it out pop the new ones in bolth um up...sounds too easy..anyone know?
JLB
Old 05-03-2011, 04:25 PM
JLB
Yup, that's pretty much all you have to do. You should only have to lift the rear at the frame/body to get clearance. In other words, don't lift it at the differential. You should be able to compress the shock by hand to fit it in the mounts.
Always use jackstands, of course.
Old 05-03-2011, 07:14 PM
matts37chev's Avatar
I don't understand?
Last journal entry: this is only a test
^^^^^^^^ x2
i agree on the jackstands
also, the spell check button before you post, is always good.
Old 05-04-2011, 04:07 AM
lol just noticed that. spell check would be good :b
Rear air shocks chevyrally68 Suspension - Brakes - Steering 8 11-29-2010 04:54 PM
70's 12 bolt rear to replace 80's 8.5 rear MRGM Transmission - Rearend 4 02-07-2008 08:25 PM
Need to replace my coilover shocks... 36scsc Suspension - Brakes - Steering 5 12-06-2004 02:24 PM
Jag rear end shocks farna Suspension - Brakes - Steering 3 11-26-2004 07:49 PM
rear shocks beetle9 Suspension - Brakes - Steering 2 03-02-2002 05:44 AM
