how to replace rear side window on 39 chevy business coupe - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-14-2014, 08:24 AM
EagleOne's Avatar
I have tried but the will not go in I have new rubbers. Spray with glass cleaner and push one side will go but not the other like they are to big.
Old 01-14-2014, 09:12 AM
You sometimes have to fight it a little, tell me is the window new too?
Old 01-14-2014, 09:44 AM
EagleOne's Avatar
No same window I took out.
Old 01-14-2014, 11:02 AM
Warm the rubber up in a bucket of hot soapy water and it will give you a lot more pliable rubber, that may get you over the top.
Old 01-14-2014, 11:27 AM
EagleOne's Avatar
Soak the whole window I have the rubber over the window I am having a problem putting them on the car.
Old 01-16-2014, 11:10 AM
Born Again's Avatar
Who made the rubber ? Metro rubber co., or Steele rubber co.
Old 01-16-2014, 03:58 PM
EagleOne's Avatar
Don't know They did not have any markings on them bought them from Chevy of the 40's
Old 01-16-2014, 10:41 PM
I meant of course to heat up the rubber in hot water, then put it on the glass and install it. Using a thin rope of some sort is the way to go usually.
There are a number of videos on youtube that show it being done.
Old 01-17-2014, 04:14 AM
EagleOne's Avatar
Front window and back window I already put in it is the side windows I am having a problem with. the ones in the back. The side windows are made different than the front they only have a small lip on the outside.
Old 01-17-2014, 06:50 AM
Born Again's Avatar
Don't want to bash a company, but more than likely they are Metro. ( would have been on the bag they came in. ) I blew $70.00 on a pair of vent window rubbers that turned out to be 1/4 " too thick, and 1 " too short...........had 1 " of daylight showing. Ordered another set from Filling Station ( Steele Rubber ) , and it was dead on. You could order a set, and compare it to what you have now, and if they are the same you could return them. But I have a feeleing I'm right.
Old 01-17-2014, 03:54 PM
EagleOne's Avatar
They came in a box with the front and the back window with no name on them. I got them on the window nice and tight but putting them on wont go..
Old 01-18-2014, 05:47 PM
Carpoor's Avatar
After putting the rubber on the window, I put it in place and screwed the inside molding tightly against it, then used a plastic pry tool to work the rubber out little at a time. Used soap and water,and did the install by myself. Chevys of the 40s rubber. Rear (back) window seal from Chevys of the 40s would not work for me. Had to order one from Steele which worked out great.Hope this helps..
Old 01-19-2014, 09:42 AM
EagleOne's Avatar
Thanks I will order new ones and try.
Old 01-19-2014, 04:45 PM
Carpoor's Avatar
Maybe I worded it wrong, but I did use Cheyvs of the 40s rubber on the quarter windows. It was the back window I had the problem with the chevys of the 40s rubber. Hope this clears this up.
Old 01-20-2014, 06:58 PM
EagleOne's Avatar
I had no problem with the windshield or the back window with Chevy of the 40's rubber just the side windows.
side window channels ford 34 coupe scaryeyes Body - Exterior 21 07-01-2014 07:31 AM
Side Window Alignment - '68 Mustang Coupe 3ponyshow Body - Exterior 1 02-07-2012 06:58 PM
1947 Ford business coupe side trim? yekoms Body - Exterior 2 04-07-2007 09:18 PM
Single side window in a 47 Chevy Coupe? MN48 Body - Exterior 1 12-13-2005 06:21 AM
the rear section of a 31 chevy 5 window coupe hotrod389 Body - Exterior 3 12-03-2005 10:35 AM
