How to replace a steering gearbox seal..... - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-23-2008, 07:06 AM
I have a leaking seal on the power steering gearbox on a '69 Coronet and was wondering if any can tell me how to pull it apart to replace the seal. Or, should I take it to a pro.
Old 08-23-2008, 12:45 PM
thems a pain , you get the arm off ?
i used small sheet metal screws and drilled into seal .
i put a 1/4 inch nut as to not go in to deep and hit bearing .
don't strip screw into seal , back off and remove nut .
then used a carpenters small pry bar ,the flat one with right angle short side for pulling nails , put screws back in leaving a gap ,thin pry it out .
four screws work good so as to walk it around and remove it even , this will keep from pulling screws out .
Old 08-25-2008, 11:08 AM
I would remove the pitman arm, dust seal, than take the snap ring out that retains the seal in. Than start up the engine and let the ps pump pressure blow the seal out, you may have to work the steering wheel back and forth some, just remember where center is at before you start. Than find a pipe or something the size of the seal to drive the new seal back in.
Zoop Seal coating for polished aluminum, RESULTS!!!!!!! fordSR Engine 15 02-05-2010 12:04 PM
Ford Truck Steering woes Kaylah Suspension - Brakes - Steering 4 08-15-2008 05:09 PM
77 dodge b20 van steering questions briansansone Suspension - Brakes - Steering 1 04-13-2006 03:31 PM
Rear Main Seal 1985fiero Engine 1 04-27-2004 09:31 PM
Power Steering Hose Connections Larry D Suspension - Brakes - Steering 3 12-02-2003 07:06 AM
