How to replace window lift motors? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2007, 01:07 PM
I need to replace the rear window lift motors on a 2001 Olds Aurora.Can anyone give me any info on this? Tip,Tricks,etc.... thanks fellas!!!
Old 03-07-2007, 03:16 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
The best tip , is beg, borrow , or steal a Factory Manual..and follow it religiously..
Use Magnetic Tools..to lower the possibility of losing screws, nuts and bolts in an unreachable body crevasse, as well as place shop rags around the body at the bottom of the well, to catch anything dropped..
Be sure the harness and plugs are not getting pinched, cut, or have dirty or loose pins..burnish the body side harness (the old one) Pins so they are clean and make good contact.
Be sure your motor ground is properly bonded, burnish the paint from the area, use a star washer, and lock washer, and be sure it is tight..99% of window failures are bad motor grounds..
If it requires the glass be removed, REMEMBER the angles you used to get it free..and duplicate when putting it back in..don't try to force it, it will explode in your hands..wear safety glasses while doing it..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 03-07-2007, 04:37 PM
How to replace window lift motor?
As Doc said, GET A MANUAL!! If you can't borrow, beg or steal one.see if the local library has one. They wont let it leave the building, but you can copy what you need. Done this more then once, believe me. I tape plastic over any opening where something might get dropped,can't rely on a manet all the time, too much "crap metal" in the newer vehicles.
setting points on sb chevy frackster66 Electrical 23 01-07-2014 06:50 PM
old inground hydraulic lift wont go down wheel-7 Garage - Tools 16 05-27-2012 01:22 PM
Lift Kit CustomFord Suspension - Brakes - Steering 1 05-09-2006 04:21 PM
1.7 to 1.8 ratio BBC rockers much diff...? Bumpstick Engine 6 04-29-2005 12:41 AM
Power Window Problem Steven_O' Electrical 2 03-29-2004 02:09 AM
