how to run 383 stroker on pump gas - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-13-2011, 08:52 PM
im trying to find a way to how i can run my 383 stroker on pump gas. it has 12.5:1 compression so i was mixing 50/50 with pump and 100LL. that started to get old and exspensive fast so i switch over to E85 and bought a E85 carb. come to find out thats not working out to good for me either. i would like to just lower my compression so i can run on pump gas and have 400whp. this is what my car has
port matched and angle milled bow tie heas with stainless manley valves 2.065 int 1.625 ex 58cc combustion chambers
flat top pistons
victor jr intake matched to heads
3/8 chromemoly pushrods screw in studs plates and roller tip rocker arms
292H comp cam with rhodes lifters
850 holly double pumper with rear power valve
msd 6a electronic timing control
i know i want to get some aluminum heads for it. would that and some larger cc work with pump gas? or would i have to change to some inv pistons? also before i switched carbs to e85 it ran a best of 13.1 at 108 at the track on street tires. help please!!!!!!
Old 08-13-2011, 10:35 PM
If you want to save money and don't mind doing the work. Put thicker head gaskets on it to drop some compression. You can use a compression calculator and figure in what thickness of gaskets you need to get the compression your looking for...
Old 08-13-2011, 10:40 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
How do you come up with 12.5 c.r.?
Even with zero deck, .041 gasket and 58 cc heads and -6 cc for valve reliefs I get 11.8. If your pistons are .025 in the hole it's 11.01, both a little high, but you should be able to tune it to run on 93 gas.
That being said, at zero deck, and 64 cc heads you have 10.35, 72 cc's will get you 9.54.
You're also over carbed IMO, what trans and gear, car weight? 11:1 is a little high, but isn't unheard of for good pump gas if you have the right tune and setup.
Semper Fi
Old 08-13-2011, 11:11 PM
thanks for the replys!!! yeah the gasket would help. i thought about that too. so heres the story. i bought the car from a guy that built the engine for a dirt car. he then dropped it in the el camino then lost interest in it and it sat for 20 years. he said it had 12.5 compression and built the engine so i was just taking his word. it dont seem like that much but i know its high like probably 11.5. im not to sure on all the specs on the engine. all i know is what i typed. i did notice that it seems to run smoother on e85 and it doesnt want to choke or cough when i shut if off anymore. i just want to rum pump gas. i dont want to have to fill up jugs everytime i need gas. i dont think its every had a tune. it did run really good before i switched it though. i think the carb is a 830cfm. thats just what it came with when i bought the car. it has a muchie 4 speed with 373 gears.
Old 08-14-2011, 12:13 AM
yeah i was thinking some 64cc int202 ex 160 heads. would that be good? then get a thicker head gasket. how thick you think? also how are you coming up with the 11.8 compression? i would like to get about 10.5 and run 92 octane
Old 08-14-2011, 11:30 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Here's one of many free calculators online, it'll help.
Semper Fi
Old 08-14-2011, 12:38 PM
ok so i was messing around with the calculater and i came up with 12.7 compression. did i type in something wrong? heres what i did
cylinder di. 4.030 in
stroke length 3.75 in
cylinders 8
chamber 58 cc
pistons flat top 0
gasket .041
i found if i go with 74cc heads i would drop down to 10.5 if everything is correct above. would 74cc heads with flat top pistons be best or 64cc heads with dish pistons. im lost on the difference between the two besides the size. i want to gains power and still drop compression.
Old 08-14-2011, 06:13 PM
cylinders 8
chamber 58 cc
pistons flat top 0
gasket .041
You need to know piston to deck to know what the compression ratio is I don't see that you included that. Your flat tops are not likely zero CCs of relief. They are probably 6cc or close to it.
Gain power and drop compression? Probably not going to happen without a power adder or a cam swap done as well. Which brings up another thought, you may be able to just leave the compression and use a cam that has more overlap, duration thus building less cylinder pressure.
There are other things you can do to make the engine less pone to ping.
160-180* stat
Overkill cooling system
Overkill ignition system
Cold air intake
Thermal coatings on intake, pistons, exhaust ports
Lower gear ratio in diff to take the load off the engine
Use no more total timing than needed
Polish combustion chambers
Block off heat crossover (if currently used)
Plus more
Old 08-14-2011, 09:24 PM
techinspector1's Avatar
Wiki Edits: 326
BZZZZZTTT, wrong answer. Thicker gaskets will lower the static compression ratio, but they will also increase the squish, resulting in the motor detonating worse than it does now.
Old 08-14-2011, 09:35 PM
how much cam do i need. i have a pretty big one right now. also one person says -cc pistons the other +cc. on the calc it said 0 for flat - for dish + for dome. i think im going to just go with some 72cc heads and get a tune. that seems to be the best im going to get. just use a .041 gasket. i dont know what deck it has but assuming a 0 deck would be the worst case right
Old 08-14-2011, 10:10 PM
yeah i get what your saying. i just dont know much about the engine i bought the car that way it is. i mean how much cam do i need to drop compression and gain power? i have a 4 speed muchie. 373 gears the guy said max rpm is 6500 but i pushed it to 7000. so 72cc aluminum heads with drop the compression but will they also add hp or will the drop in compression and the aluminum heads just even out to where i am now?
Old 08-14-2011, 10:30 PM
no its a wide ratio muchie 4speed. its not a drag car. i just want to have a low 12 high 11 sec street hot rod. i'll take it to the track a little still. im not to worried about the gears. i like the 373 thats in it now. the car is a 64 el camino. i still would like to know more about smaller and larger cc heads. is that all just based on the pistons you have and compression you want to make?
Old 08-14-2011, 10:37 PM
when i was mixing gas it ran a 13.1 and 108. i was thinking about the AFR 195 eliminators heads
Old 08-14-2011, 11:46 PM
Not sure what the specs for your cam are, but look at it this way. The more duration and more overlap in the cam means less cylinder pressure build up during the compression stroke.
Have you done a PROPER cranking compression test?
From what I have heard, small CC heads and dished pistons is better than big CC heads and flat tops. Another thing to think about. Aluminum heads are always nice.
Old 08-15-2011, 12:13 AM
yeah i'll give afr a call and talk with them. i was just looking at the cam. it has a 72 overlap. it did seem to run a little rough at idle then smooth off when i got on it. another thing i should bring up is it has a lot of blow by. what is that about?
Ford Fuel Pump Pressures--In tank pump Bryan59EC Engine 9 06-28-2011 02:56 AM
Is it normal to have to pump the gas several times to get accelerator pump squirt ? fumplet Engine 3 11-16-2010 01:14 PM
Which type of fuel pump for stroker sooper Engine 1 12-25-2009 10:36 AM
help, electric water pump for stroker? bear1980 Engine 11 09-30-2007 08:50 PM
Starter won't start and fuel pump won't pump after engine reinstall Porschev Electrical 26 02-16-2007 04:43 PM
