Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to run my front brake lines?
Old 04-15-2013, 10:43 AM
kso's Avatar
kso kso is offline
Yeah you don't want it pulling tight anywhere.
I'd run it straight down (or nearly so), then curve alongside the lower control arm (a couple inches up from it) then s-curve up to the frame fitting so that it can flex in tandem with the arm and twist with the spindle. Assuming the length and frame fitting work with that.
Brake line routing seems like a simple thing but can take hours and hours.
The Following User Says Thank You to kso For This Useful Post:
panhead1961 (04-15-2013)
