Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to run my front brake lines?
Old 04-15-2013, 11:56 AM
Irelands child's Avatar
Irelands child Irelands child is offline
You don't have to run a banjo fitting. You need an adapter - straight to either pipe or -an(or whatever the caliper threads are. Here are photos of various combos:
https://www.google.com/search?q=cali...w=1700&bih=783
You will need to search for the correct -an fitting for your application.
This is kinda out of focus, but my original intent was to show the DOT approval for the braided flex lines and shows an adapter on one end and through frame fittings on the other:
Irelands child
