How to save crusty chrome on an intricate grill? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-01-2012, 12:41 PM
Cleaning dirty chrome
I had a '55 T-Bird with wire spoked wheels. I used the Eagle One Chrome & Wire Wheel Cleaning Kit with great results. It is a 2 part application, the first part being an acid cleaner that is left on for 30 seconds (I left it on longer the first time) then rinsed off. The second step is to spray the neutralizer on and let stand for at least 1 minute. Rinse again with water. The wheels looked like they were right out of the box new when done. Give it a try.
  #17 (permalink)
Old 02-05-2012, 07:18 AM
if it's just surface rust try using C.L.R. it works on bathroom chrome.I have seen some posts on the HAMB where a guy used it on surface rust on his 60's chevy wagon. it came out great.on the plus side you will have a clean bathroom if it doesn't work out.also comes in small bottles, less $outlay.
  #18 (permalink)
Old 02-05-2012, 08:13 AM
grille mesh 34 master
Originally Posted by madmike3434
i saw on an australia site they soaked the part in brown MALT VINEGAR and it took the rust off....
that grille mesh is made reproduction in stainless steel.
mike
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
harris engineered reproductions
P O Box..800991
houston texas
usa 77280
phone 1-713-826-0419
fax... 281--856--9423
email .... info@hergrilles.com
they have a web site....google it
they make AS ORIGINAL stainless grill mesh inserts for 1932 to 1936 chevrolet models , plus the center strip piece and also for 1934 master only a repo grille trim ring.
mike
  #19 (permalink)
Old 02-05-2012, 09:17 AM
topwrench's Avatar
Last journal entry: fish carb
You asked about cleaning the rust,try OSPHO it will completly neutrlize the rust.
Its a phosphoric acid based product.
  #20 (permalink)
Old 03-21-2012, 02:39 PM
Silver Surfer's Avatar
More machine than man
Last journal entry: bwaahhaahahaaahhaa
Originally Posted by Elevinpointsixtoone
I acquired this amazing original 34 Chevy Master grill..all 3 pieces that have been hiding in an old hot rodders attic since the late 50's. If your familiar with these the intricate grill work has thicker vertical strips top to bottom and then finer horizontal shaped strips that run horizontal molded onto the backside of the vertical ribs. Its fine and tight spacing...less than a quarter inch between each horizontal ribs. The entire grill is chromed. It would be almost impossible to get something down between the ribs to clean the rust and crust off those horizontal strips. At least with any control. Is there some kind of chemical dip that removes this corrosion without damaging the steel or chrome plate? I've cleaned enough to see that the chrome is intact...just not sure which way to go with this.
The ONLY way I will ever remove rust is with this stuff:
http://www.theruststore.com/Evapo-Rust-Gallon-P1C1.aspx
You pour it on, let it sit, what doesn't fall off by itself, you just literally wipe off with a rag. I know this sounds like magic/info-mercial, but this stuff is legit.
  #21 (permalink)
Old 03-21-2012, 03:31 PM
Elevinpointsixtoone's Avatar
I'll bite...at only $23 for a gallon well worth the risk if it even comes close to doing what they say it will. I wonder if Lowes or Home Dep carries this stuff?
Thanks for the tip!
Dave
  #22 (permalink)
Old 03-21-2012, 03:57 PM
Thanks for the tip!
Dave
I'm tell ya the stuff works! Check your PM's. If you live near KC and you don't like it, let me know and I will buy it from ya!
How can I de-chrome my grill 28 Essex Body - Exterior 9 02-01-2012 01:14 PM
Crusty Cruiser ONE CRUSTY ONE Introduce Yourself 3 07-10-2011 12:33 PM
Air bags, yes they save your life, but they don't save you from injury. MARTINSR Hotrodders' Lounge 3 11-09-2008 02:33 PM
massive crusty corrosion on/in radiator KNanthrup Engine 7 07-18-2006 01:54 PM
crusty astrops Body - Exterior 2 06-02-2004 08:38 PM
