How to seal inside rockers - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-26-2006, 08:14 AM
I'm in the process of restoring a 69 LeMans. I have patched the rocker panel on the drivers side in two places (outer rocker) and need a small patch on the inner rocker before I replace the floor pan supports.
I want to spray some master series epoxy primer inside the rockers after I'm done patching. I have a small undercoating system from Eastwood I used for my boxed frame rails but had to really thin out the material to get it flowing right.
Is there a better way to get sealer into tight spaces such as the rockers or inside boxed frame rails?
Thx...Kron
Old 04-26-2006, 08:19 AM
There is a product called "cavity wax" that you apply to the inside of any welded on parts like a rocker or frame rail on a unibody car. It is applied with a long plastic tube that has a nozzle on the end.
3M makes one called Rust Fighter part number 8891.
Old 04-26-2006, 09:00 AM
agree, cavity wax is as good as it can be
of course, the challenge is.....flushing the 40 years of crap out that's in there so the wax can stick better to the rust scale
sharp hammer blows...forced air....gets the loose stuff...welding loosened some already
Brian, your gona love my "mud" solution.......
mix 10 different soaps and detergents in your hose end insecticide sprayer, spray hell out of it, tape the front drains,spray more in, trap as much as you can, let it soak, then rinse and blow dry, if you can drive the car, seal the rear drain go slosh the soap and water around.....your car is now a washing machine
what kills rockers is every time you use reverse the rear tires throw the crap and water into the rear rocker drain, do what you can to "shield" them but don't(!) close them up...the faster steel can dry with air flow the longer it will last
Old 04-26-2006, 11:46 AM
Thanks. I've never heard of this product. Will cavity wax seal surface rust inside the rocker or will that have to be "neutralized" first? They have been cleaned (blown down).
Kron
Old 04-26-2006, 12:13 PM
ooooooooh noooooo! don't ask that question!!!! I can "feel" a 100 posts thread coming!!!!
seriously, just click on the knowledge base link above and enter "rust" in the search box in the body exterior section
how's this for an answer: won't really help, won't really hurt, anything...
Old 04-26-2006, 12:45 PM
Will do.
Thx again...Kron
Old 04-26-2006, 07:53 PM
Old Jag Trick
Don't know if this will work for you, but....
On the old E-Type jags, the frame rails were hollow and tended to rust from the onside out so the fix was to drill a hole on the top of the rail , dump a quatr of oil in there, plug the hole and drive like a madman around an empty parking lot on a Sunday morning to slosh it around really well.
Don't know if it did any good but it shure was fun.
Old 04-26-2006, 09:16 PM
Kron
Kron, the cavity wax will attach itself and seep into the surface rusted panels, it provides a self healling barrier to keep moisture, oxygen from feeding the rust. A coating like POR would also be good but it would be impossible to prep and clean these interior surfaces for a good application. a few applications of 3M's rustfighter, or Transtar's Amber Coating, or Amsoil's version will work well. Tape the lower pinchweld closed so this seam fills up completely and make sure the drains in the inner rocker are open when you are done.
I agree on Red's idea about dirt/mud being the major cause of corrosion in these areas. Dust collects in these areas and eventually holds moisture causing corrosion. Dust will actually wick moisture into crevices like a sponge. Bob
Old 04-27-2006, 04:05 AM
Baddbob, well put, "self healing" great description
all I could think of was candle wax on a table......not a correct description
Old 04-27-2006, 04:37 AM
deleted, doesn't apply to this car
Old 04-27-2006, 08:08 AM
I'm sorry Red, but a half inch angle is going to do very close to nothing for you in that applicaton.
Either you repair the rockers damage or you do nothing, a little strip of metal isn't going to help you.
The 69 LeMans is a full frame car, the rockers are no different convertible to hardtop because they aren't doing as much as on a unibody convert.
Old 04-27-2006, 09:05 AM
Brian, do agree,
I'm having one of those "my brain is not plugged in at all days"
went back and deleted post
Old 04-27-2006, 11:04 AM
Will I ever get it done?
Last journal entry: Hood
The full frame GM cars like the 69 LeMans had boxed frames where the sedans and hardtops had open channel frames. I think the Ford and Chrysler uni-body cars had extra "boxes" welded to the floor pans in strategic areas for the convertibles.
Old 04-27-2006, 11:10 AM
You are right (sort of, but we will get to that in my PS ) my point was that the rockers are no different sedan to conv.
PS Hows this for a trivia question: There is a GM "A" body that did have a boxed frame in the sedans and coupes 1965-66, which one?
There was actually two, I'll give you one, but there were only about four made, the other was production. The 65 Chevelle I think it was called a "Z16" that had a boxed frame with a coupe. What was the other?
Old 04-27-2006, 05:43 PM
I was rushing at lunch. I should have added that the factories kept the convertibles from folding up by means other than reinforcing the rockers. The rockers were the same.
I am going to guess. I know the GTO and Chevelles (save the Z16's) had open channel frames. The 442?
Zoop Seal coating for polished aluminum, RESULTS!!!!!!! fordSR Engine 15 02-05-2010 12:04 PM
55 chevy, 265 rear main seal slingslingbinks Engine 5 10-19-2004 09:27 AM
Front oil pan seal on Small Block Chevys gearhead77 Engine 19 09-26-2004 08:58 PM
Rear Main Seal 1985fiero Engine 1 04-27-2004 09:31 PM
Rear Oil Seal Replacement 71gtx Transmission - Rearend 2 03-09-2004 01:35 PM
