how to set my timming - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-12-2008, 08:52 PM
on my 300 6 cylinder I went to set my timming on my truck with a timming light and the notch on the harmonk balencer is't there what do I do because one time I would just loosen the distributor and turn it untill it sounded right but I turned the timing to high and started breaking starters, and I really don't know what year model the motor is because it is'nt the original motor that come in it, and I went through 8 starters that came from o'reilly before I reilized the timing was to high, so about 4 half months ago I pulled the timming down and pulled a starter off a 69 351 windsor and it works pretty good but the timming is still not right can any body help me.
Old 08-12-2008, 10:34 PM
SSedan64's Avatar
If you're sure you have the timing lite connector on the #1 plug wire the outer ring on the harmonic damper may have spun/slipped. If so you need a new damper before it comes loose and flies through the hood or radiator.
Old 08-13-2008, 02:40 PM
I'll try that
Thanks I'll get one immedintly thanks.
Need Help Choosing Cam And Timing Set 400smb_s10 Engine 1 06-11-2007 05:56 PM
Camshaft Timming APOSTO Engine 1 06-10-2007 06:50 PM
Holley choke set screw lluciano77 Engine 11 08-05-2004 10:20 PM
Where to get a set of Unilug washers and nuts to fit? Dubz Hotrodding Basics 1 07-06-2004 07:33 AM
Wut set of heads for my set up? Trav Engine 2 10-15-2003 09:45 PM
