How to set timing - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-28-2010, 06:15 PM
How to set timing
I am building a high performance engine how do I set the timing when the cam gives it a lope
Old 09-28-2010, 06:36 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
You are going to have to give more info then this. Give all your engine specs.
And what trans and converter and rear gears also. What are you working on exactly ?
Cole
Low buck 355 sbc not running correctly, wanting to much timing. ForceFed86 Engine 67 04-13-2011 12:35 PM
Question on torrington roller bearing timing chain set. eric32 Engine 4 11-09-2009 09:17 AM
adjustable timing chain set ? blzr7.4 Engine 1 09-04-2009 12:45 AM
sbc timing question 350pano Engine 8 05-15-2009 10:30 AM
what RPM to set timing & carb??? yragat Engine 3 08-28-2008 01:34 PM
