Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - how to set total timing
Old 10-01-2010, 12:33 PM
bubbahotep's Avatar
bubbahotep bubbahotep is offline
That link has all you need but also check many of fbirds posts for more details. Disregard vac advance until you get the total set and the advance curve you want. If you're using an old distributor chances are it has some sort of advance curve already set , you can work with that
