How to set-up 600 cfm edelbrock's on a 2x4
Recently purchased a Weiand 2x4 manifold for a sbc. Has anyone used Carter or Edelbrock 600 cfm with any luck? If so what jetting did you use ? The engine is a 350 with 202 heads,dished pistons,Crane 100172 cam,Accel . I already have the carbs,they fit good,don't want to spent $500.00 on 500 cfm's. Thank you
SBC 2x4's
I have a 28 Ford coupe w/ 2 600 CFM Edelbrock carbs on it. I haven't had to fool with the jetting. Being that they are vacuum secondaries they only open up as needed. What I have done is turn in the idle mixture screws all the way and back off on the idle screw of the front carb. What this does is that the engine only idles on the back carb. Make sure you use progressive linkage.
Being that I have 3.55's in the back and a 4 speed the car runs like a mad maniac. I am extremely happy. Have fun - Jerry P.S. the SBC is a .060 283 Last edited by fred56; 02-10-2012 at 04:27 PM. Reason: Adding info |
Thanks for the info,I'm sure it will be helpfull.
| Edelbrock's new e-210 heads | Prostude | Engine | 4 | 10-26-2010 12:04 PM |
| 2 questions: Edelbrock's Pro Flo injection and 194 inline power tips | loyter | Engine | 4 | 04-20-2006 02:11 PM |
| Edelbrock's Triangle Air Cleaner: Good or Bad?? | Oreif | Engine | 14 | 02-05-2006 09:21 AM |
| Edelbrock's RPM cam? | bowtieorbust | Engine | 4 | 11-09-2003 11:25 PM |
