How to setup gm rear end - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-05-2006, 08:01 AM
I need some place to get info on setup for gm reag axle setup . I am swaping out the oem carrier and putting in a aurburn high perf lsd . re using the old ring gear 3.73 and not removing the pinion gear. having new side bearings also. Anyone have this info or a web site to get the correct procedure for doing this . Thanks in advance for your help. Jim
Old 02-05-2006, 08:18 AM
That's a pretty simple swap.
Since you're not removing the pinion gear, you don't have to worry about pinion depth.
I would say that all you need to do is: determine the backlash as it sits, and install the new carrier with whichever shims it takes to give the same backlash, and the proper bearing preload for the new carrier bearings.
JA
Old 02-05-2006, 09:04 AM
BOBCRMAN@aol.com's Avatar
Many transmission shops or supply houses will stock the special replacement shim kit for these rear ends. It consists of two large shims that allow the fine adjustment shims to be installed into them. This package is then installed on each side of the carrier.
Old 02-08-2006, 08:43 AM
Thanks for the replies guys, Any place on the web to get the specs. for this rear end . I don't have a book available , thanks Jim
8.8 Ford rear end in my 79 G body Malibu 79 Malibu327 Transmission - Rearend 4 05-20-2007 02:26 PM
Cadillac rear end, ID help Firecop57 Transmission - Rearend 1 06-12-2005 12:33 AM
Rear End Gunk? MrChevyDC3 Transmission - Rearend 2 02-19-2004 05:48 PM
Rear end identification help 71gtx Transmission - Rearend 1 11-07-2003 07:14 PM
anyone running 700r4 with 3.55or 3.77 rear end? 37 chevy Transmission - Rearend 7 01-06-2003 06:34 AM
