Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to sew an inset panel?
Old 06-08-2013, 07:01 AM
DanTwoLakes's Avatar
DanTwoLakes DanTwoLakes is offline
Wiki Edits: 22
Yes, there are some pictures of how to sew an insert with a round top. I'll see if I can find them. I just did some seats for a 71 Roadrunner that had round top inserts. I don't think I explained this very well, you don't double the seam allowance on the insert. The piece the insert is sewed to has it's seam allowance, and the insert has it's seam allowance. If you are using 1/2" seam allowances, the two parts overlap each other by 1". Here is the seat, and the pattern I used to make the seat cover. The line on the top piece is the overlap needed to sew the two parts together which is double the seam allowance, a total of 1".
ID:	74675   Click image for larger version
ID:	74676   Click image for larger version
ID:	74677   Click image for larger version
