Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to sew an inset panel?
Old 06-08-2013, 09:33 AM
John long John long is online now
Originally Posted by slodat View Post
Let's see if I'm following.. The actual seam will be 1/2" (the seam allowance) "in" for lack of a better word, from the pattern edge on both parts?
Also, is the insert pattern's outer edge the same as the line on the other panel? It appears that way. And, I think that makes sense. Making a test piece now..
I think what he is saying Slodat is to make your insert just a little larger than it needs to be. Start sewing your seam from the center of the panel toward the corner. once you get to the corner and turn your 90 continue straight back to the end of the panel. That way you won't have any bunching at the corner. Next, repeat from the center to the other corner and do the same.
Hopefully Dan will be back sometime over the week end and clarify.
John
