How to sew an inset panel? - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-06-2011, 05:38 PM
I made a tuck and roll panel that I would like to inset into a panel. I tried to make a test piece, I traced the tuck and roll panel, then I drew lines toward the inside the width of my seam allowance. I then tried to sew it to the tuck and roll piece. I'm having trouble getting the corners to lay flat.
How do you sew this?
I'm trying to replicate the lines that were heat stamped into the original vinyl on my boat.
Old 02-10-2011, 07:39 AM
DanTwoLakes's Avatar
Wiki Edits: 22
The insert needs to overlap the opening it goes into by double your seam allowance. If your seam allowance is 1/2" the insert needs to be 1" bigger all the way around. If your seam allowance is 3/8" the insert needs to be 3/4" bigger all the way around.
Another trick of the trade is to make the inset panel an inch wider than it should be, center the inset panel in the middle of the piece above the insert, sew to the corner where it turns 90 degrees, turn the corner and follow down the insert the same distance from the outside edge of the insert. It should be 1/2" in from the edge of the insert, but it may be 3/8" or 5/8". Whatever it is, follow down the edge of the insert that width. Then do the same thing sewing to the other corner, make the second 90 degree turn and follow down the same way.
The point is that you can always make the insert smaller, but you're screwed if it needs to be bigger.
Old 06-08-2013, 12:32 AM
Last journal entry: Getting Started with Upholstery
I know this is an old thread. I thought sure Dan had posted photos with an explanation of this. I'm having a hard time with a curved insert going into a panel. I know to double my seam allowance, but it's not going as well as it should.
Dan, do you have the photos that I'm thinking I remember seeing? Or, am I crazy
Old 06-08-2013, 07:01 AM
Wiki Edits: 22
Yes, there are some pictures of how to sew an insert with a round top. I'll see if I can find them. I just did some seats for a 71 Roadrunner that had round top inserts. I don't think I explained this very well, you don't double the seam allowance on the insert. The piece the insert is sewed to has it's seam allowance, and the insert has it's seam allowance. If you are using 1/2" seam allowances, the two parts overlap each other by 1". Here is the seat, and the pattern I used to make the seat cover. The line on the top piece is the overlap needed to sew the two parts together which is double the seam allowance, a total of 1".
ID:	74675   Click image for larger version
ID:	74676   Click image for larger version
ID:	74677   Click image for larger version
Old 06-08-2013, 09:17 AM
Let's see if I'm following.. The actual seam will be 1/2" (the seam allowance) "in" for lack of a better word, from the pattern edge on both parts?
Also, is the insert pattern's outer edge the same as the line on the other panel? It appears that way. And, I think that makes sense. Making a test piece now..
Old 06-08-2013, 09:33 AM
I think what he is saying Slodat is to make your insert just a little larger than it needs to be. Start sewing your seam from the center of the panel toward the corner. once you get to the corner and turn your 90 continue straight back to the end of the panel. That way you won't have any bunching at the corner. Next, repeat from the center to the other corner and do the same.
Hopefully Dan will be back sometime over the week end and clarify.
John
Old 06-08-2013, 10:24 AM
Wiki Edits: 22
No, I'm not saying to make it bigger. If you did that with a round top, it would really get screwed up. The seam allowance for both parts, the insert and the part it gets sewed to, should be the same. What I'm saying is that you can check it by just laying one pattern on top of the other and when you do that it should overlap by double your seam allowance. For 1/2" seam allowance that would be 1". There is a mathematical correlation between the two parts that has to be as accurate as possible for the finished piece to look right.
"Also, is the insert pattern's outer edge the same as the line on the other panel? It appears that way. And, I think that makes sense. Making a test piece now.. "
Yes, the line on the top piece was traced right off the round topped insert pattern.
When you make your patterns, start with the insert and then make the rest of the parts accordingly.
The Following User Says Thank You to DanTwoLakes For This Useful Post:
John long (06-08-2013)
Old 06-09-2013, 10:23 AM
Thanks for the clarification, Dan. Practicing these again today.
Old 06-17-2013, 08:58 PM
vinyldude's Avatar
beginners contribution
hello, i learned much from this forum, and lots of practice. my inserts don't always come the same, so i take my insert and place it on my seat material, trace it and then measure 1 inch in and that will be my cut line, hope this helps. cheers
Name:	falcon rear seat 015.jpg
ID:	74979   Click image for larger version
Name:	falcon rear seat 016.jpg
Old 06-18-2013, 07:37 AM
Wiki Edits: 22
Like I said, start with the insert and go from there.
46 panel IMRasputin Introduce Yourself 2 01-04-2010 09:02 PM
installing color panel in door panel studebaker2 Interior 1 12-30-2009 06:45 AM
sub-panel tspags Electrical 2 02-10-2008 06:23 AM
the door panel Question to end all door panel Questions Hogwild Interior 1 02-05-2008 01:24 PM
cracking where fibreglass panel grafted to metal panel goldstarr Body - Exterior 2 11-22-2002 06:44 AM
