how short to make drive-shaft - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2003, 07:14 PM
I change the rear springs on my nova and went to reinstall the drive shaft but its seems that the company that made the springs don't know how to measure. The rear end now sits slightly more forward and I can't even slide the yoke far enough into the transmission to do the u-joint up. I think I'm gonna get the drive shaft shorted tomorrow but I"m trying to figure out by how much. At ride hight how should the yoke be from bottoming out on the output shaft? Right now at ride height i think its just bottomed out.
Old 10-16-2003, 07:24 PM
dmorris1200's Avatar
doesn't play well with others
I would have to double check but I think with the suspension loaded (like when she's sitting normally on the ground) you should have about 1" to 1 1/2" from being bottomed out. I actually posted what mine was cut to but that was last year.
BUILT FORD TOUGH
Old 10-16-2003, 07:30 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Is it possible that the tie bolts on the springs are offcenter meaning that you could have the springs on backwards?
Take a good look and double check everything before you go getting the driveline shortened.
Old 10-16-2003, 07:36 PM
No I actually considered that possibility but I"m sure they are on the right way with the particular bushing they use in these springs its pretty hard to get them on backwards.
Old 10-16-2003, 07:37 PM
Oooops, that would suck>
I just checked incase you do need to cut and I allowed 1" from bottoming out. Good call BstMech.
BUILT FORD TOUGH
Old 10-16-2003, 10:36 PM
Alright well I"m gonna remeasure it and see but I think I'm gonna have to have it shortened an inch thanks for the help guys
Old 10-16-2003, 10:49 PM
Gene Neal's Avatar
springs
Perhaps! Just maybe the spring company put the bushing on the wrong end of the springs! ----------------------------------------Gene Neal
Old 10-17-2003, 03:16 PM
ya thought of that one to but the center bolt is off set toward the front on these cars and thats the way these are installed.
Old 10-17-2003, 10:19 PM
Gene Neal's Avatar
springs
R/R! I just have to ask a dumb question, sorry but: are you sure that the spring center pin bolt is in the proper hole in the rear end housing and spacer block? I have seen the thing assembled with the c/pine in the square hole on the spacer block and the spacer block pine in the right hole on the rear end. this would give you the same type problem. Drive shaft to short or to long. I'm not even sure if you use a spacer block or not but I thought that it might be worth noting also if the spring are not the right one's, would it be possible to get the right one's instead of modifying your drive shaft. I assume that it all worked OK before the R and R . Well, I'm out of ideas. May be dmorris1200 has more to offer or someone one else on the board. ------------------------------Gene Neal
Old 10-18-2003, 09:31 AM
Re: springs
To tell you the truth Gene I've never had to shorten a driveshaft because of a spring replacement. Of course that doesn't mean much since most of the springs I've replaced have been replaced with OE parts. Since this is the internet we also don't have the advantage of being able to get a hands on inspection. I had to shorten my shaft because I went from a 8inch to a 9inch rear and when I cut mine I was told 1" to 1 1/2" was how far out my slipyoke should be with the car on the ground.
BUILT FORD TOUGH
Old 10-18-2003, 07:20 PM
adtkart@aol.com
If all you are changing is the springs, you shouldn't have to shorten the drive shaft, unless you are really making a BIG difference in the stance of the vehicle. Since normally you can bottom out the suspension without bottoming out the drive shaft, something sounds really wrong. Aren't your tires too far forward?
Old 10-18-2003, 07:48 PM
Thanks for the help guys I figured it out today, at the same time a changed the springs I swapped from a 8.2" 10 bolt to a 8.5" which was suppose to be a direct swap but I did some measuring today and from the center line of the axle to the u-joint flange seems to be about 1 1/4 longer than the 8.2 inch hence the extra length. Ohhh cars nothing ever goes as planed
Old 10-18-2003, 10:02 PM
Gene Neal's Avatar
springs
I'm glad to hear that you found the problem. And yes, I can see how that would make the deference. I do believe that Dmorris1200 had a hint about that in his last post. let use know how it all turns out. --gene Neal
Old 10-19-2003, 05:31 PM
Well today I went to the wreckers and was measuring drive shafts it seems that all the car equipped with the 8.5" 10 bolt axles have a drive shaft that is 1 INCH SHORTER than the ones equipped t with the 8.2. I feel kinda dumb not having thought of that earlier but i had been told by so many people that it is a direct swap it never even occured to me anyway I pulled a drive shaft from one and got it for 20 bucks and just finished installing it, perfect fit. Anyways thanks alot for the your help guys glad I finally got to the bottom of that one
