Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - how should epoxy lay down?
Old 06-27-2009, 06:23 AM
cboy's Avatar
cboy cboy is offline
Last journal entry: Finished
Originally Posted by isaac338
...running about 25 psi with the trigger pulled...
Is that at the gun or at the compressor? Also, is 25 psi the mfr's recommended setting? If I recall correctly, the purple gun (43430) runs best in the mid 40's at the gun.
Always learning...and sharing what I've learned.
