Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - how should epoxy lay down?
Old 06-27-2009, 07:40 AM
isaac338 isaac338 is offline
Originally Posted by cboy
Is that at the gun or at the compressor? Also, is 25 psi the mfr's recommended setting? If I recall correctly, the purple gun (43430) runs best in the mid 40's at the gun.
That was 25 psi at the gun with the trigger pulled, 45 without. Should it be 45 with the trigger pulled? My gun is stamped 43 psi max, I'm a little worried about going high enough to get 45 with the trigger pulled!
