Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - how should epoxy lay down?
Old 06-27-2009, 06:05 PM
cboy's Avatar
cboy cboy is offline
Last journal entry: Finished
Originally Posted by isaac338
Should it be 45 with the trigger pulled?
I believe so, yes. But to be on the safe side you could go up in 5 lb increments as Sam suggested and spray on some test panels until it goes on smooth and flat.
Always learning...and sharing what I've learned.
