How should I modify my '38 Dodge headlight buckets for halogens - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2008, 06:10 PM
38Dodgebiz's Avatar
Gearhead for life
Last journal entry: Swapped out the bow-tie bling
Hey guys,
I am in the process of wiring my '38 and I am trying to decide how to modify the headlight buckets for 12v - halogens. Has anyone done a write up on modifying the old buckets? Should I try to use the old lenses and reflectors and fit new sockets in somehow or is there a better way to approach this? I see kits for some makes but old Dodges aren't as popular.
Thanks, Tom
Edit - adding some pics to clarify what I am starting with:
Old 11-16-2008, 07:16 PM
302 Z28's Avatar
What is the diameter of your buckets? It may be possible to purchase drop in units. Whatever you go with consider upgrading the electrical supply to the halogen lamps with relays and heavier wire. The improvement in brightness will be dramatic.
Vince
Old 11-16-2008, 07:44 PM
38Dodgebiz's Avatar
Gearhead for life
Vince
Hey Vince,
The outside diameter of the buckets (trim ring) is 8 3/4" and the inside opening is 7". I am installing an 18 circuit painless wiring kit and plan to replace all of the old wiring inside the buckets and tailight housings. No old wiring will be used anywhere.
Please let me know if you have any links to kits that might work for me.
Thanks, Tom
Old 11-17-2008, 07:13 AM
302 Z28's Avatar
You can buy lenses in 7" diameter that accept standard halogen H4 bulbs.
I am not talking about reusing old wiring. Even with a new Painless harness the wires that feed the headlamps are too small for halogen. You need to use relays so you can shift the load from your headlamp switch to relays. The end result is a headlamp switch that will last forever and headlamps that are 50 to 75% brighter. See the attached file.
Vince
Old 11-17-2008, 08:55 AM
38Dodgebiz's Avatar
Gearhead for life
Vince
Thanks Vince - understood - I will definately be using relays. Thanks for the attachment - good info.
I have taken some pics and attached them in my first post. They should help clarify what I am starting with.
Thanks again, Tom
Old 11-17-2008, 10:06 AM
47chevy's Avatar
Last journal entry: Here is the car after paint
Here is a 35 Pontiac that I modified the bucket to install a 7" sealed beam. The Halogen light also fit in here but I did not take a picture of it.
[IMG][/IMG]
Here is a 7" Halogen H-4 frenched in a 47 Chevy.
[IMG][/IMG]
Old 11-17-2008, 04:46 PM
RetroWill's Avatar
You might talk to the tech guys at Dennis Carpenter Reproductions. On my 1935 Ford stock headlamps I used one of their kits to update to halogen bulbs and retain the stock Ford script lenses. It's more work than modifying them to install a halogen sealed beam but it depends on what you are after. The stock Ford lenses are very close to the size of yours.
I wanted that original lens........and they work awesome now too.
Old 11-17-2008, 05:00 PM
38Dodgebiz's Avatar
Gearhead for life
Thanks - yes I would like to retain the original lenses and trim rings if possible and replace the old bulb (2131) and socket/pigtail. I have seen some Ford kits on eBay that I might be able to customize and retain my original "Riteway" lenses and original reflectors.
Thanks, Tom
Old 11-17-2008, 08:08 PM
38Dodgebiz's Avatar
Gearhead for life
Here is a kit I found (only $39) that I think will work. I am guessing that I can open the hole in the reflector a little to accept the socket which is held on by a retainer. I can use my original adjusters, lenses and bezels. I'll probably need 1 new bezel (kinda dinged up) but the other bezel and both lenses are good.
Old 11-18-2008, 07:22 AM
RetroWill's Avatar
There ya go!!! That will give you the light you need and retain your original look.
The H4 bulbs make a HUGE difference in lighting.
Old 11-18-2008, 12:31 PM
38Dodgebiz's Avatar
Gearhead for life
Yeah it's pretty cool and it's an inexpensive solution too. I just went to SoCal Speed Shop here in Phoenix and got the same basic kit for $39.99. It even comes with instructions (but it's obvious what you need to do).
Just in case anyone else is traveling this path and trips across this thread:
- the kit is made by Vintique Inc.
- the Vintique inc. part number is B-13026-QH12
- SoCal's part number is A6243
- the part is called: "Quartz Halogen Headlamp Conversion Kit"
Old 11-18-2008, 02:56 PM
123pugsy's Avatar
"Thread Cop"
Last wiki edit: Metal shaping
Last journal entry: SEAM SEALER
Wiki Edits: 29
Thanks for the info. This is exactly what I will be doing later.
Pugsy
Old 11-21-2008, 02:45 PM
Hey, do you have measurements of the rings for the kit? If not it isn't a big deal I just kinda wondered.
Ford headlight buckets 41Ford1 Electrical 1 02-07-2008 06:31 PM
headlight buckets for my 37 37plydude Electrical 1 08-20-2005 01:21 AM
38 Dodge Bros. Pick-up johnauto Body - Exterior 1 10-17-2004 01:44 PM
38 headlight lens/cover 38 special General Rodding Tech 7 07-29-2004 12:54 AM
38 Dodge ralphy Transmission - Rearend 1 01-04-2002 02:59 AM
