how should i prime a spot - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2011, 05:22 PM
rusthater89's Avatar
i recently applied epoxy primer over a media blasted fender. afterwards i applied body filler over the spots that needed it. it turned out i didn't use enough hardener and it was not good. I scraped all the filler off with a broad flat head driver. it left me with some scratches down to bare metal.
should i just run a da sander over the entire affected area and just touch up the scratches with more epoxy or am i doomed to sand the whole panel down and start over
Old 08-25-2011, 05:34 PM
milo's Avatar
point on positive
Primer before filler is way over rated and causes more problems than it solves for the new to the autobody game..
Yes DA with 80gr to metal. then filler straight on that and primer after body work like in the good ole days..
Here's 3 secrets that'll help
http://www.a2zautoforums.com/showthread.php?t=936
Old 08-25-2011, 06:38 PM
i have already completed 3 other panels with the epoxy under filler and i haven't had any issues i would like to complete this one the same way
Old 08-25-2011, 08:00 PM
Rag top bird's Avatar
Hot rods are still the king
I have done this both ways I have been using epoxy over bare metal for 10 years now I have never had a problem on the other hand I have applied filler over 40 grit scratches for years to with no problem and yes I would feather the scratches and reprime
Old 08-25-2011, 09:20 PM
is it required that the primer be feather edged before re applying primer considering the spots will have filler applied over it
to prime or not? roykuz Body - Exterior 3 08-06-2007 03:40 PM
Anyone have any exp. with ppg v-prime HARDEIGHT Body - Exterior 2 09-20-2005 04:57 AM
Should i prime my motor or not? Streetmaster Engine 6 09-09-2005 07:00 AM
TO Prime or not to Prime 70chevy Body - Exterior 8 06-04-2004 09:49 AM
To prime or not to prime Chevy Thunder2 Body - Exterior 9 02-12-2004 11:39 AM
