-   -   How should I reduce 2k urathane primer? (http://www.hotrodders.com/forum/how-should-i-reduce-2k-urathane-primer-68367.html)
firechicken383 08-17-2005 08:09 PM
I am using Nason Urethane primer and it mixes 4:1. However, I have to mix it a little thinner to spray out of my gun, I'm gonna get another gun or a 1.6 or 1.8 tip just for primer work soon. However I need to primer a bare metal hood tomorrow. I have always used the reducer/activator to reduce it more to like 4:2. I was told the other day, maybe I should reduce it with lacquer thinner. Would that be OK? Is the extra reducer/activator causing any harm? I know it lays down real good, and still blocks out easily.
Another question, I was getting some paint to paint my wheels with a few weeks ago and I was in the paint room, and they just have 1 set of colors for both the PPG and OMNI paint. I told him I wanted the OMNI and he mixed it using the PPG labeled colors. So, wouldn't that mean that PPG and OMNI are the exact same? Or am I overlooking something?
Thanks
beemdubya 08-17-2005 08:28 PM
Just go to the jobber and get a quart or gallon of nason basecoat reducer.. gallon is less then 20bucks.
jeffw 08-17-2005 09:37 PM
i would get the same reducer as belongs in thge mix, you can over reduce to get a thinner mix.. it just gases away anyway. as for omni and ppg yes they are owned by ppg so just a lower line for ppg.
Bee4Me 08-18-2005 07:27 AM
Look at This
Where in AR. are you located? I'm South of L.R.
firechicken383 08-18-2005 04:15 PM
I got some extra Nason reducer so I'll try that first.
Bee- I live in N.E. AR, next to Jonesboro.
