how to spray clear coat on car? - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2009, 11:35 PM
hey, looking for any tips and tricks for shooting clear on a car. I tried for the first time today and the base went on great but the clear has little dimples in it, and alot of them. what i did was spray 3 real light coats of clear, but it looked kind of rough, so I applied 2 heavy coats but looks like i got too much on there, plus you can still the little dimples in the clear. so should I just not spray light coats and just apply heavy coats right off the get go? any help is apperaited, thanks.
Old 06-06-2009, 12:42 AM
001mustang's Avatar
spraying clear
Some people spray one mist coat first to minimize runs before the official first coat is applied; personal preference.
Read the instructions carefully.
Last time I sprayed, I just shot two wet coats of clear (per instructions); except for the edges and corners where I sprayed an extra coat because paint tends to be thin on corners.
Err on to much flash time instead of to little flash time between coats.
If clear does not go on slick then I apply a maximum of one extra wet coat of clear to give extra film thickness so I can color sand it flat before buffing.
If your clear coat is to thick then you can have problems.
If you want to be sure you are spraying slick coats then you can tune your gun on a scrap metal test panel.
My first pass of setting up a gun is: set pressure per instructions, verify nozzle size is close to spec, set fan control wide open, set fluid control wide open, then do a test spray to see how fast I must move the gun.
Old 06-06-2009, 01:27 AM
Spray it on like you want it too Look
The dimples are from contamination of the surface before you sprayed
Sand till the dimples are gone..CLEAN PROPERLY
Respray... Put it on like you want it too look
Your light coats caused the rough look
Too heavy and it runs
52F1
Old 06-06-2009, 10:58 AM
mitmaks's Avatar
Last journal entry: Grille
it's possible you sprayed clear coat on too light resulting in dry spray. I usually apply one medium coat followed by wet coats. Also after first coat let it flash for 5 mins, after 2nd coat for 10 and after 3rd for 15... and so on.
Flames without the clear coat?? Yes or No Jim Weeks Body - Exterior 4 04-13-2009 05:21 PM
"Basic of Basics" How do you properly apply filler? Centerline Body - Exterior 2 02-10-2006 12:22 AM
Painting roof tips needed..... Bluepen Body - Exterior 7 09-10-2005 09:26 PM
First paint scheme for '59 Caddy by me Nightrider Body - Exterior 54 07-05-2005 02:27 PM
Clear coat starting to dull after 3 months help please anthonycn Body - Exterior 9 09-02-2003 01:22 PM
