how to stiffen springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-20-2006, 07:14 AM
how do you stiffen up a pair of front coil springs? i bought a set of 3" lowering springs for my 66 impala. look is good but exhaust scrapes a lil on bumps. if i could stiffen the springs a lil it will fix it.
Old 08-20-2006, 12:38 PM
xntrik's Avatar
Save a horse, Ride a Cowboy.
Need new springs or taller tires.
Old 08-20-2006, 01:41 PM
just looking 4 a quick fix. only drive car less then 1,000 miles a year
Old 08-20-2006, 05:36 PM
You could always try those getto "spring rubbers". Should be able to find them at autozone and the like (most likely won't find them at a good parts store) for about $5.
Did you install new/any isolators when you put the springs in? They go up top in the coil bucket. Replacing your old ones might get you a smidge more ride height (but won't stiffen it at all)
Old 08-20-2006, 05:40 PM
poncho62's Avatar
Wiki Edits: 5
You put lowering springs in it, and now you complain that it's too low..................I think the answer is obvious.
Old 08-21-2006, 02:24 AM
Any way to custom-contour the exhaust?
Old 08-21-2006, 11:44 AM
the only place that hits the ground on a good bump s the header collector. I luv the way the car sits right now just would like a little stiffer spring so it won't bottom out so easy. thanks guys
Old 08-21-2006, 12:14 PM
That being the case you might want to look into bump stops. The old fashion solid rubber bump stops are not what I would use. A good bump stop example would be the ones used on S10 ZQ8 trucks front suspension. These trucks came lowered 2" from the factory. They came with polyurethane foam bump stops that almost touch at ride height. Unlike solid rubber bump stops they start out very soft and get much stiffer very quickly. They go for about $20 each at a GM dealer (you can only get them at a GM dealer!) and have a stud sticking out of the metal bracket making them very easy to mount. Your car will still ride nice but not bottom out.
Old 08-21-2006, 12:30 PM
OneMoreTime's Avatar
Hotrodders.com moderator
Wiki Edits: 3
Excellent idea but with my crs I wiil not remember this tip..I have put a shim in the upper spring cup when I needed to lift a car just a small bit..
Sam
66 Impala Springs........ black66 Suspension - Brakes - Steering 2 11-02-2007 12:15 AM
Consequences of wrong springs on my heads? TVR383 Engine 6 11-23-2005 10:25 PM
Diffrent Springs? strikingthematch Engine 3 12-09-2004 09:12 PM
HEI Springs Sweet-34 Hotrodding Basics 5 04-14-2004 11:46 PM
Valve Springs GearHead69 Engine 5 07-19-2003 11:00 AM
