how to stop peeling clear - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-29-2012, 01:05 AM
cutthroatkid's Avatar
two cups of tea
Last wiki edit: Need more horsepower for my 305 Last photo:
Wiki Edits: 2
Ive got some peeling stock clear in the door of my truck.Im just wondering can I go behind the clear&wet sand it down &shoot it with some clear to stop it?
Old 01-29-2012, 04:10 AM
deadbodyman's Avatar
Wiki Edits: 11
nope, it would be like clearing over a burn through from buffing,the base has to be put on first...
If it can still feather back (with a DA) and if its only a couple spots you can feather it and rebase it (sometimes) but usually ALL the clear has to come off...A razor scraper is what I usually use but be careful not to scratch the base too much or too deep...
Old 01-29-2012, 09:39 AM
two cups of tea
Wiki Edits: 2
Thabk you sir.What Im wondering is right below the window it has pin stripping &the peeling is above that.So is looks as if its stopping it from going it past that am I wrong?Also is it possibe to get the rest of the clear off with a power washer?
Old 01-29-2012, 09:51 AM
swvalcon's Avatar
Last journal entry: rust on lt body shell
Biggest problem with a power washer is controlling the spray. I have removed a lot of clear with a non osha approved air blower. depends on how bad the clear coat is.
I have wondered if it is the clear failing, or is the UV attacking the base coat and the surface of the base coat is degrading, breaking the bond to the clear.
Old 01-29-2012, 02:43 PM
Wiki Edits: 11
They usually only peel down to the stripes because thats where the direct sun really cooks the clear....since its mostly the tops that peel and the clear always turns whitish first,its my opinion that its actually the clear and its mostly because the clear isnt thick enough....Then theres the repaints that turn white and peel and those I have to blame the base either being cheap low end type that was applied too thick and not completely curing before being cleared or mabee from adding reducer to the clear ....Then again you have the dodge peelers and those are definetely an epoxy primer problem...So theres a few causes depending on what you have....air blowers work pretty well,razor scrapers also work well if your careful........BUT...I know a little trick and all I'm going to say about it is one thing, Can you say Gorilla glue duct tape?????????? 10 times stronger than regular duct tape??????
Old 01-29-2012, 03:19 PM
two cups of tea
Wiki Edits: 2
Great info!
Clear peeling right off of base color cyclopsblown34 Body - Exterior 22 11-28-2007 08:13 AM
peeling....paint? BMM Body - Exterior 5 02-15-2007 04:22 AM
Clear coat delaminating, can I stop it? Jeepster Body - Exterior 4 07-07-2006 05:50 AM
peeling chrome rajin-cajin General Rodding Tech 7 01-08-2004 07:08 PM
Fixing peeling clear coat..... OddsNEnds Body - Exterior 29 06-21-2003 08:03 PM
