how straight is straight enough (push rods) - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-22-2003, 08:32 PM
minesblown's Avatar
i made a strightness checker for pushrods which works fine but i don't know whats acceptable. my daily delima is the ones that were in the motor are 1 peice harded type. the look straight but the dial indicator moves about 6 or 7 thousants on average on these. i have a new set with the ball ends, and they only make the indicator move 2 or 3 thousants. i would rather use the 1 peice ones but are they straight enough?
Old 10-22-2003, 08:34 PM
poncho62's Avatar
Wiki Edits: 5
Roll them across a piece of glass. That will tell you if they are straight enough, Simple as that!
Old 10-22-2003, 08:46 PM
1 to 3 is okay. . .7 is to much. The latest trend is to go back to large diameter pushrods due to defection at high rpm and under heavy spring loads. I have had a customer change pushrods and gain 30HP. I would use a good .080" wall 5/16 if this is SBC or a 3/8" in a BBC. If it were a race engine 7/16".
Cstraub
Old 10-23-2003, 12:54 AM
minesblown's Avatar
thank you very much i will go with the new ones
Old 10-23-2003, 08:05 AM
Wrencher's Avatar
30hp???
Are you sure? maybe they had the wrong ones in the first place?
Old 10-23-2003, 08:32 AM
willys36@aol.com's Avatar
Wiki Edits: 21
Cheap insurance. The best ones are still pretty cheap.
Old 10-23-2003, 08:38 AM
troy-curt's Avatar
Shop Owner And Troll Hunter
I've always done it like Poncho does.
Troy
Old 10-23-2003, 10:50 AM
Yes Im sure. . .you could tell on the dyno sheets with the variation in airflow that the pushrods were rebounding. This was a 42K BD2000 headed 417 dirt engine. Serious piece. 790HP at 6800 rpm. 30HP gain going from 5/16" to 7/16" single taper pushrods.
Cstraub
Old 10-23-2003, 11:10 AM
Wrencher's Avatar
I could see that!
