How to strip a vette[paint] - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2002, 07:14 PM
Post How to strip a vette[paint]
Can anyone tell me the proper way to strip the paint on a vette. Car has been repainted once before and in the florrescent light you see cracks in the paint all over the car so iam sure it must be time to strip it?
Old 09-23-2002, 10:36 PM
Halloweenking's Avatar
Fantastically cannibalistic!
Post
Actually depending on circumstances it could be the car itself due to the fact that corvettes are fiberglass, unless of course its the recent bodystyle. The safest way to strip a corvette ththtat I'm comfortable with is to sand it down to the base rimer/sealer and go from there. I myself don't use any solvents on fiberglass just because I have exstremely sheety luck and don't dare to do it. There could be something new, but I don't know of anything. Just strip it by sanding with a D/A and prime and paint, some people I know put flex agent in the paint for fiberglass, but personally have never had a chance too, nor see the reason to due to fiberglass's regidity.
HK
Old 09-24-2002, 01:49 PM
oneangrypuppy's Avatar
New Member
Post
Not really my experience, but my Corvette owning/restoring friend always recommends careful scraping with a razorblade to get the bulk of the paint off, and pretty much the same advice as HK gave you.
Old 09-24-2002, 01:56 PM
BstMech's Avatar
NYOFP4RJ3CHRIS
Post
All I can say about this is DON'T SAND THROUGH THE GELCOAT. Didn't mean to holler, but my brother is a body man and he has told me stories about this.
Old 09-24-2002, 05:01 PM
Post
I agree very much so with bstmech, do not sand through the gelcoat, if you do this that spot will be forever a paint black hole, it will absorb anything you put on it. So be carful and only sand off what needs to be sanded off for the repaint, otherwise it could get ugly.
HK
Old 09-24-2002, 05:11 PM
Post
Thanks everyone for your imput,just thought maybe
there was some really new way to strip it. Sounds
like this might be my winter project since it is
going to take quite a bit of time. Think I'll pass on the razor blade tho.
Old 09-28-2002, 08:59 PM
Post
I am going to have to respectfully disagree with some of the other posts on this one. I have two corvettes that I have owned for the past 25 years and I have painted both of them. When I first started I got a book on the subject that did not recomend chemical stripping because they said it would hide in the door jams and come back later and lift your new paint off. Following their suggestion, I tried to sand the old finish off, and found it to be very time consuming, labor intensive, dusty, and was dificult to do without getting into the jell coat. There is a special paint stripper designed for fiberglass that I got from the body supply shop and it stripped all layers of paint and primer down to the jell coat. (takes 2 gallowns) I found this to work very well, and it was much faster than the sanding process. Before I started I taped the jams up to keep it out of the cracks, then carefully sanded those areas when I pulled the tape off.
Before you start stripping paint I would make a drawing where all your cracks are so you can examine the body to see if the body is craking or if it was caused by the paint film being too thick. If it is the body, you will need to repair this first before you paint it.
Old 09-28-2002, 09:13 PM
Post
Hotrodman, I'm always up for new information, like I said there could be a chemical stripper out there. Whats the name of it, just like to add it to my knowlege for future use.
HK
Old 09-29-2002, 06:24 PM
jwcnj45's Avatar
Post
We use a product called Aircraft paint stripper in the shop where I work. They make one for metal and one for stripping fiberglass. It works well on Vette's as long as you thoroughly clean it off the body by giving it a good wipe down with lacquer thinner before priming or sealing for paint. As far as the jambs are concerned we just cover over the gaps with a strip of duct tape so that the stripper does not get into these areas. These areas are then sanded by hand to remove the finish. We have done quite a few Vette's and other car panels such as the newer Camaro's and Firebird's that use composite panels and have had no problems with it. If you do sand through your gelcoat their are products made to correct the problem. We use Sikken's Poly Surfacer over bare glas and gelcoat sand throughs and then recoat with primer surfacers or sealer prior to paint.
Old 09-29-2002, 06:53 PM
Post
Ok, that paint remover I was using that removes the paint and leaves your gel coat alone is also available from Eckler's Corvette in catalog 1202 on page 241 listed under restoration parts. Its called auto spra - strip item number 13024, comes with a spray bottle, sells for $29.99 a gallon plus shipping. (Usually takes 2 gallons) They also have books and videos on page 186 that give specifics on fiberglass repair and painting. You can probably find it at ecklers.com under restoration parts, or they will send you a catalog free by calling 1-800-327-4868. Hope this helps.
Old 10-04-2002, 08:03 PM
Post
Again thanks everyone for your advice the stripper sounds like the best way to go.
1934 Top Tack Strip StreetFord Body - Exterior 2 05-18-2005 05:55 AM
Headliner gripper strip question on my 49 Fleetline Rodrunner Interior 2 05-27-2004 08:41 AM
Victor Jr vs Holley Strip Dominator 68chevelle_ss Engine 6 05-13-2004 11:53 PM
Chemical Strip Prices? GMW Body - Exterior 3 01-14-2004 08:09 PM
Steet and Strip stall speed? MuscleBlock81 Engine 16 10-30-2003 08:19 PM
