How Strong is a Chevy 10 Bolt Rearend - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-03-2002, 11:53 AM
Question How Strong is a Chevy 10 Bolt Rearend
I have a 76 Monte Carlo with a 10 bolt posi rearend. I plan to install a 400cid 425HP with 452 ft. Lbs. of torque. I plan on changing the transmission from a TH350 to a TH400.
My question is: Is the 10 bolt rearend strong enough for street (Hot Rodding) ?
*I am using 275-60-R15 tires on the rear.
*The car weighs 3900#
Thanks for your help !
Old 04-03-2002, 06:01 PM
Tom Tom is offline
Post
should be plenty strong enough if it doesn't have any problems now they're pretty tough
Old 04-04-2002, 10:22 AM
Post
big joe the 10 bolt is very strong but boy that is a vey heavy car and it will really pull on that 10 bolt.
i used one in my t bucket for many years and that 327 c.i. engine was built but the weight of a t is nothing near 3900 lbs.
useing an auto trans will save you though as they can't put as much of a load as a standard tranny might..
good luck
bomo
Old 04-07-2002, 05:04 PM
Post
i have 80 malibu i put a 12 bolt out of a 69-70 chevelle only thing i had to do was cut of the coil spring mounts and leaf spring mounts then weld the coil spring mounts on the 12 bolt. make sure to measure were the coil spring mount are monted on the stock rearend then weld same place on 12 bolt hope this will help your journy..
