-   -   How to swap rear differential ? (http://www.hotrodders.com/forum/how-swap-rear-differential-10071.html)
kemo 02-05-2003 02:59 PM
I have a 69 camro with a 10 bolt 8.20" 28 spline rear end. I want to put in an auburn gear limited slip diff. I have never done a differential swap before and want to what all steps are included when swithcing a rear differential.
kiaserknife 02-05-2003 03:29 PM
It is a very detail orianted process..if you have never done one...you will need a manual or a friend who has, to help quide you thru the process...if not set up properly..your gears wont last very long in the least...
