How to take apart crimped gauge housings? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-02-2007, 10:23 AM
Last wiki edit: Calculating tire size
Last journal entry: Changes...
Wiki Edits: 2
I want to put the original speedometer and fuel gauge from my camaro into some gauge housings I have, to make it easy to mount in my custom dash. The gauge housings I want to use are crimped shut, do I need to bend open the crimp? How do people normally open these up?
Russel
Old 11-03-2007, 07:01 AM
Vortech 4.3's Avatar
jack of all trades
"people" don't cut them open. they are permanent. to open it would most likely destroy it. but, you could take a die grinder and cut it open behind the crimp. install your new stuff. and somehow or another, perhaps weld, it back closed.
Old 11-03-2007, 07:12 AM
poncho62's Avatar
Wiki Edits: 5
make the dash fit the gauges, rather than making the gauges fit the dash
Old 11-03-2007, 08:36 AM
kruzr's Avatar
street rods forever
If you really want to use (insert)your old gauges ,you dont necessarily have to open the crimp.
Cut the other end of housing off carefully so the glass doesnt break,
your old gauges probably wont fit that older bolt hole pattern.
Plan a way to mount your "old gauges " into end of housing.
Seems like a lot of work to have custom dash with old gauges but might look nice... long as you like it thats all that matters....go for it
I wouldn't advise any welding any where near the gauge itself
got any pics?
question about ballast resistor and wire gauge redneckprofessor Electrical 25 06-09-2007 01:50 PM
Guages are dead gtipton Electrical 4 05-09-2007 09:14 PM
mechanical oil gauge bleeding? cboy Engine 5 06-28-2005 04:37 PM
Need help with fuel gauge Crazy-J Electrical 3 03-01-2005 11:46 AM
Twilight Zone and my temperature gauge unstable Engine 8 10-08-2003 03:57 PM
