how to tell fords 7.5 from 8.8 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-22-2005, 12:30 PM
85stangboy's Avatar
New Member
i have a 86 mustang originally a 6cyl now has a 351w and my friends have been telling me that i need to change it to a 8.8 bc it should be a 7.5 for a 6 cyl how do i tell the difference
Old 02-26-2005, 09:54 AM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
measureing horizontally(side to side, not up and down) the bolt holes are 9.5" apart on an 8.8 housing.
Old 02-26-2005, 06:47 PM
The 8.8" has straight sections on all 4 sides, while the 7.5" is curved on the sides and straight on the top & bottom. Both have 10 bolts on the cover.
Old 02-26-2005, 09:31 PM
Last wiki edit: Window removal and installation Last photo:
Wiki Edits: 11
You don't really HAVE to. I swapped a 5.0 into my wife's 86 about 5 years ago. I just KNEW I needed to put in an 8.8", but didn't. To date the 7.5 has held up just fine. I'm sure it will give up sometime, but our situation is such that we can leave it be until it starts giving trouble. Or goes kerbang. Note that we're not running a 351W though. Nor do we race the car or anything.
8.8 Ford rear end in my 79 G body Malibu 79 Malibu327 Transmission - Rearend 4 05-20-2007 02:26 PM
swapping axles - Ford 8.8 ?? 49T&C Transmission - Rearend 1 05-12-2004 10:09 PM
using a ford 8.8 or 9" gears on my 7.5 FoxThunder 5.0 Transmission - Rearend 2 10-23-2003 08:47 PM
8.8 rear questions mike bryan Transmission - Rearend 2 05-19-2003 03:38 AM
Ford 7.5 vs 8.8 rearend ID copper128 Transmission - Rearend 3 11-25-2002 02:43 AM
