how to tell if its a posi - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-10-2008, 04:36 PM
If you have a rearend assy out of a car laying on the floor is there a way to tell if it's a posi without pulling the cover? No tags or anything like that on it
thanks
Old 01-10-2008, 05:26 PM
put it on stands and spin one wheel, the other wheel should go in the same direction, if is a posi. if its not it will spin opposite of the spun wheel.
Old 01-10-2008, 05:47 PM
stand method works
you can hold the yoke and if the wheels turn opposite
direction easy ,it's no posi
Old 01-10-2008, 07:00 PM
A Big Thank You!!!! :d :d :d
Old 01-10-2008, 08:13 PM
Last journal entry: A few ongoing projects
If your buying, pull the cover or third member to make sure your really buying a posi and not a POS with welded spider gears.
Old 01-12-2008, 02:23 PM
If when you say "posi" you mean a GM Posi-Traction® differential made by Eaton then yes you can do the spin the wheel test.
If when you say "posi" you mean a clutch pack type limited slip differential then yes you can do the spin the wheel test.
If when you say "posi" you mean any type of traction adding differential then no you can't always do the spin the wheel test. For example a GM Gov-Lock® (made by Eaton), Trutrac® (now owned by Eaton but designed by TracTech), and Torsen® (made by Zexel-Gleason and used in some late model F-bodies and Mustangs) will all act like an open differential with the spin the wheel test.
And people wonder why I don't like the use of the word "posi"
Old 01-12-2008, 04:54 PM
I guess best bet is to pull the cover
Old 01-12-2008, 05:05 PM
you are confusing the poor guy
Old 01-12-2008, 05:16 PM
He did come to the proper conclusion. It is always best to pull the cover off and find out for sure what gears are in it, what diff is in it, and what condition it is all in. If it is out of the car you don't even have to drain the oil to pull the cover off - just point the pinion down.
Old 01-19-2008, 06:44 PM
Marcel
Last journal entry: Choo-choo town
How To Tell If Its Posi
If I'm buying, I ask to pull the cover to confirm what it is. You can check ratio and type at the same time. If its what you want, then buy a gasket, cheap insurance. If they won't let you pull it, must be something wrong. M2C
I blew my Auburn posi apart this week end. ElCa/monty Transmission - Rearend 3 07-02-2007 10:08 PM
ahhh what do I do? mixed up beraing cups, budget 8.5" posi install Warrant Transmission - Rearend 7 03-23-2007 09:39 PM
to posi or not to posi Gmachine Transmission - Rearend 17 03-23-2004 04:00 PM
7.5 Limited Slip POSI Aaron930 Transmission - Rearend 0 02-05-2004 10:18 AM
Posi? novatech Transmission - Rearend 3 01-09-2004 07:05 AM
