How to tell if it is ss or bc/cc - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-19-2009, 03:49 PM
My car just came back from the painter and it looks very nice, but it just occured to me that i do not know how to tell by looking if it is base coat/ clear coat as i asked him to do. Is there an easy way to tell? Thanks,
Bill
Old 04-19-2009, 04:43 PM
A clear job they say looks deeper, but there are certainly nicely done single stage jobs that look plenty deep, so it could be hard to tell the difference just by looking.
Only way I would know for sure is if you could sand a hidden spot or use rubbing compound on a spot(if you could sand or compound a singlestage without affecting the color can be a risk, and a metallic would be a no go for sure)
.A single stage with no clear over it would turn the sandpaper, water(wetsanding) or compounding pad color, since you are hitting the pigment. A single stage a very thin layer of clear resin actually does float to the top and help protect the pigment, but would require very little to be through it, Clear when sanded will be white. So it still would be hard to tell for sure if the color is white.
I'd hate to think any reputable painter would screw a customer and charge and tell them they are getting a base clear and then spray a single stage to pocket the amount of money difference between the two, and risk ruputation and future work. If I was working at a place and found out they did something like this to a customer, I'd be walking. No decent bodyman or painter would want to be associated with a place that did something like that either. But I suppose there are a few shady characters out there. I think most would prefer to shoot a base clear anyways in most cases, because along with it often being easier on them to shoot (especially metallics and pearls), and also if a mistake happens to be made to repair, and most colors and metallics is going to hold up to uv longer, and metallics are going to look better with a clear over them.
Old 04-19-2009, 05:23 PM
im sure if they charged you for a bc/cc paint job then thats what you got how long did they have your car?
Old 04-19-2009, 06:50 PM
Bill
WAX ... IF it is a Clear coat when you wax it you will see no Color on the rag
SS will show the color of the paint on the rag
52F1
Old 04-19-2009, 07:07 PM
BMM BMM is offline
Do NOT wax it if the paintjob is fairly recent.
Old 04-19-2009, 08:16 PM
71corvette's Avatar
Iagree you can cause all sorts of problems. the paint solvents can get trapped under the wax
Old 04-21-2009, 08:12 PM
Just put a few drops of polish on a cloth, rub a small
spot that dosen't show, and see if paint rubs off on
the cloth. If there's no color transferred to the cloth,
it's a BC/CC. Color on the cloth means it's a SS.
painting black use bc/cc or ss otis808 Body - Exterior 4 04-17-2009 12:53 AM
Is my Monte Carlo SS a "True" SS Lance1 Hotrodding Basics 3 02-15-2009 06:54 AM
1962 Impala SS ? kgard Hotrodding Basics 4 05-30-2008 09:21 AM
ss urethane or bc/cc vintage guy Body - Exterior 5 03-30-2007 02:39 PM
BC/CC vs SS opinions on brands? jethro Body - Exterior 5 08-19-2002 01:36 PM
