Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to tell if stall converter is seated
Old 07-15-2012, 09:23 PM
Crosley's Avatar
Crosley Crosley is offline
Global Moderator
Wiki Edits: 1659
If the converter spins freely as the trans is bolted up , you are OK.
Your photo does not look like a 1/2 clearance. Looks like less.
1/2 inch is too much pull out from the trans to the flywheel. Should be around 1/8 inch
