Originally Posted by TexasT
Also rubbed some fluid on the converter hub to get it passed the input seal. You probably didn't do that either but don't worry about it.
IMO, Lubricating the convertor hub/seal is vital!
If you start that engine up on a dry rubber seal ... it's going to burn up.
Just a little vaseline or assembly lube is all you need.
