How to tell what rear end I have - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-13-2006, 08:18 PM
I have 33in tire (top to bottom) and when I turn it around 1 complete turn my Driveshaft turns (example a clock) 2 times plus 5min. What running gear am I running? Thanks in Advance, Dana
Old 06-13-2006, 08:28 PM
Jmark's Avatar
Are you turning BOTH tires or just one? If just one, you are only getting 1/2 the drive shaft turns compared to turning both tires. I'd take a guess at 4.10 gears if you double the drive shaft turns if you are only spinning one tire.
Mark
Old 06-13-2006, 09:06 PM
If the other rear tire is not moving while you're turning the other one, you're looking at 4.10 or 4.11. If you turn the wheel twice, the driveshaft turns = the ratio.
Thump Thump in rear end?? HotRodMan Suspension - Brakes - Steering 7 01-24-2007 06:09 PM
1975 8.5 rear end camino_man Transmission - Rearend 6 09-18-2004 05:32 AM
Rear End Change black66 Transmission - Rearend 4 01-28-2004 09:21 AM
Important rear end mounting question 71gtx Transmission - Rearend 2 01-04-2004 06:05 PM
Ford 7.5" Rear End Traction-Loc Install nightrain_rod Transmission - Rearend 2 12-30-2003 06:38 PM
