how to test ford ignition components..help? - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-18-2005, 08:09 PM
Steve-0321's Avatar
Ok i need to know how to test the ignition system on my 73 mustang with 351C motor. I think my coil is going out on my because i took the coil wire off the distributor and cranked it and saw two blue sparks jump to metal but then they sparks turned to orange and stayed orange. The coil is losing power correct? how do i determine its the coil for sure? the car runs...but poorly and the timing jumps around also. Is this a big ignition system fix or what? thanks for any advice
Old 10-19-2005, 04:27 AM
docvette's Avatar
Wiki Edits: 12
Testing
Doc here,
This testing procedure is valid for just about any automotive coil. Using an ohmmeter, check the resistance between the side terminals of the coil. Do this with all of the wires to the coil disconnected.
You should see 0.75 to 0.81 ohm of resistance. Then check the resistance between either side terminal and the center high tension terminal. The reading should be 10,000 to 11,000 ohms. Any significant deviation from these numbers would indicate that the coil is defective.
73 Mustang STOCK Ignition Diagram...
The left is a V6 the right is a V8...If the coil checks good you may have Governor issues..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 10-19-2005, 06:42 PM
larryblack's Avatar
Certified Lead Foot
Try cleaning the coil with electrical contact cleaner. Make sure it is NON RESIDUE type. The spark jumping usually indicated the coil is putting out OK power. It just needs to go to the plugs.
Inspect the cable tower for cracks. If you have any cracks or deteration, get a new coil.
Get some Silicone for ignitions. All auto parts stores have it. Use a Q-Tip and wipe some on the inside of the wire boot.
Do this to both ends of your wires. This helps water seal and electrical seal the connections.
46 ford p/u model # ( WRONG ) ? biglee550 Suspension - Brakes - Steering 19 03-17-2008 09:45 PM
Help me pick- Electronic Ignition Coil Francis Electrical 27 04-24-2006 06:11 AM
Ignition coil suspected of being faulty...how to test it? Steve-0321 Electrical 1 10-15-2005 05:40 AM
Henry Ford in Heaven schnitz Hotrodders' Lounge 9 10-19-2004 11:09 AM
63 Ford Changing Ignition auntiemame Electrical 0 06-25-2003 11:56 PM
