How to test that a horn works before installation - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-15-2010, 10:11 AM
I have a basic horn I got at Autozone. Highway Blaster.
If I touch the two terminals on the horn direct to cables from a battery, shouldn't it honk?
I am hesitant to pull out the old horn, put in a relay, relay socket, inline fuse, do the new switch, etc, for a horn that doesn't work.
How does one test that a horn works?
Old 11-15-2010, 10:20 AM
kleen56's Avatar
There should one or two leads on the horn. One hot wire from a 12V source goes to the connection on the horn. Horns with only one contact usually ground themselves when touched to a ground (body metal). If it has two contacts, one should be + and the other -, if you get them backwards, the horn won't work either. Even without the relays, etc, the horn should make some sound. There is also an adjustment on the horns which usually looks like a phillips screw head. I'd try it again and make sure you have a good ground. If not, take it back, get another and try it again. If the other one doesn't work, your doing something wrong.
Old 11-15-2010, 10:30 AM
That confirms what I thought, so maybe I am less of a complete idiot that I suspected.
I have touched the two leads out of the horn and the screw off to the side to pos, ground, and neg in all possible combinations on two different batteries without generating so much as a peep.
I think I will take it back and try another.
My fear was that the horn wanted more amperage than the battery could deliver and so it wouldn't honk just "cold" like that. But that didn't really make sense because a horn should honk when a vehicle is not running and 100 percent on battery.
Thanks for your input. I'll let you know if a second works or not.
Old 11-17-2010, 03:09 PM
Okay.
I took the horn back to Autozone. No problems they were very nice. The guy whipped a battery off the shelf and tested the horn the same way I did. Got nothing. Made me feel better. He futzed with it awhile and did eventually get it to make a feeble noise. He decided it was in fact defective.
We popped open another one from the rack and he tested that one as well. It immediately jumped into life.
So the answer is yes. Just touching the terminals of a standard two terminal horn across the posts of a battery should make a good horn honk.
Old 11-17-2010, 03:17 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Yep that's how i have always tested them.
Cole
Old 11-17-2010, 05:05 PM
Notlad1's Avatar
Don
I bet it's made in china.
Don
Old 11-17-2010, 05:08 PM
eloc431962's Avatar
Wiki Edits: 37
Don
I bet you are right.
Cole
StreetBeast rod kit's donaldm605 Hotrodders' Lounge 1406 07-08-2012 02:48 PM
wiring an aooogah horn dandeto Electrical 3 09-21-2010 04:07 PM
Klaxon Oo-gah horn not sounding right MortenHave Electrical 7 05-17-2010 03:35 PM
Horn problems on 67 El Camino? Madmax305 Electrical 3 04-13-2010 04:43 PM
I.Q. test willys36@aol.com Hotrodders' Lounge 57 11-25-2003 09:34 PM
