Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - How to test sensor?
Old 02-17-2003, 10:10 PM
CET's Avatar
CET CET is offline
il enforcer
[quote]Originally posted by trees:
<strong>Stude, how about leting us know what you final fix is. My knowledge base needs improvment.
No problem. I looked at it again today and pulled the distributor. I used a crude home made dial gauge and it appears that the shaft is bent however slightly. Also, now the plate inside is chewed up from the sensor plate.
I am off to find another distributor tomorrow. I will let you know how it turns out.
