How thick of filler? - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-16-2009, 06:47 PM
I was wondering is there a limit of thickness on fillers? I stripped my trans am and on the quarter by the door it was crushed pretty bad, they had probably an inch thick of bondo in some spots. I'd rather see if I can cut it out and replace it but if not, would I be able to get some really good long hair, like evercoat or that filler with aluminum in it and basically reshape the panel with bondo?
Old 07-16-2009, 07:51 PM
Will I ever get it done?
Last journal entry: Driver's Door
You're probably going to get answers ranging from none to 1/4".
1" is way, way too much.
Time to learn hammer and dolly work. Time to learn shrinking skills. IMHO, try to get to the point where you have 1/16" to 1/8".
Old 07-16-2009, 07:56 PM
I'll have to try that although the panel is really fooked up. Is there a certain dolly to get? I'm not familiar with dollies. I have a general idea what they are and how to use them but not for specialty work.
Old 07-16-2009, 08:18 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
I bought a set of dollies and hammers from jegs, And they work pretty good. Some parts stores have them also. Cole
Old 07-16-2009, 09:01 PM
302 Z28's Avatar
The less the better, should never be more than 1/4", I prefer to keep it no thicker than 1/8".
Vince
Plastic filler tips. MARTINSR Body - Exterior 14 03-03-2009 05:11 PM
The most common mistakes made by the newbe working with plastic filler. MARTINSR Body - Exterior 7 02-14-2006 10:21 PM
"Basic of Basics" How do you properly apply filler? Centerline Body - Exterior 2 02-10-2006 12:22 AM
How thick (filler) is safe? unstable Body - Exterior 3 10-15-2003 08:05 PM
