how to tie a subpanel to a main panel? - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 09-26-2006, 08:56 AM
bet on black's Avatar
hotrodder 4 life
the house panel is a 250 amp panel.
the driveway is 4" concrete. bare dirt on either side.
  #17 (permalink)
Old 09-26-2006, 10:26 AM
58Chev's Avatar
Building a 10 footer.
Last journal entry: No more room in my garage.
Is that the actual rating on the box or is the main breaker 250 Amp?
Look at the main breaker at the top of the panel, that is the true indication of what Amperage is fed into your house.
  #18 (permalink)
Old 09-26-2006, 10:45 AM
hotrodder 4 life
the main breaker is two 125 amp breakers.
  #19 (permalink)
Old 09-27-2006, 11:51 AM
panel
i sound like an old panel. there are some out there that the first 125 feeds the top of the panel and the other feeds the bottom. or it could be one 125amp feeds 120v to one side and the other feeds 120v to the other side. take the cover off to verify. ether way you should be able to put a 100amp 2pole breaker in that panel and run 4 #2 pieces of thhn copper through 2'' PVC pipe. the pipe is Grey and is for electrical feeds. the home depot will help. the reason i use a lager pipe, it helps getting it through the LB's. i will enclose a picture of the last panel that i installed. it is a 200amp main- 100amp sub-with a feed to the garage with another 100amp sub. in Michigan you can have a sub panel up to the size of the main beaker. in my case qty 2 100amp sub panels.
  #20 (permalink)
Old 09-28-2006, 11:19 PM
adtkart@aol.com
In VA your sub panel can be the same size as the main breaker also. If you think about it, there would be no reason to run one larger than the original main breaker anyway. The main breaker would trip before the sub panel would.
Aaron
Building A 302 Chevy Scorpio Shaping Flow Hotrodding Basics 6 01-16-2007 05:55 AM
Help! What To Do With These GIGANTIC Dents!? mistermuscles Body - Exterior 14 09-16-2005 05:24 AM
wanted: an answer to a simple question ikeaguirre14 Body - Exterior 4 05-15-2005 07:23 PM
Repair of large dents in roof? rlackey Body - Exterior 9 01-28-2005 10:36 PM
Quarter Panel Patch Ron M Body - Exterior 1 07-27-2004 01:12 AM
