HOW TIGHT DOES A Grilmer Belt Drive BELT SUPPOSE TO BE - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-23-2012, 01:34 AM
HOW TIGHT DOES A Grilmer Belt Drive BELT SUPPOSE TO BE? mines rubs up against the alt pulley lip & the belt throws black stuff all over. i don't want my belt to wear down or jump off
Name:	2012-12-21 16.10.09.jpg
Old 12-23-2012, 06:05 AM
thewrongshop@yahoo.com
I would think You need a more rigid alternator bracket. The bracket starts off true but when you put a lot of tension on it, it's probably flexing the bracket and pulling the alternator out of alignment, which in turn causes the belt to pull towards the front of the pulley. Gilmer belts dont need to be tight just snug to stop jumping teeth @ high RPM.
Old 12-23-2012, 11:48 AM
Been there done that. As noted, you really beed a good strong alternator bracket. If you run headers on an SBC, the Header Power Bracket is the strongest (and nicest) made and was designed exactly with that application in mind from my car.
If the belt walks forward you may be able to shim the front of the mount outward a bit to cancel this movement. Also notice how I do the "double J-Bars" with the 1/2" spacers for additional rigidity.
HEADER POWER BRACKET****** - Home
Old 12-23-2012, 01:13 PM
ok thanks
ok thanks
Old 12-23-2012, 01:25 PM
is this a good bracket to use?
Old 12-23-2012, 01:33 PM
If it works for you and does the job, it's good.
Old 12-23-2012, 01:41 PM
I would say it depends on how & where it's made and the cost could play a part. If you put a dial indicator to the back of the alternator, and or if you can move it around 30 thousands or more that would appear to be your issue, if you check some of the sites where they use this set up of belt on boats you may see that what everyone has posted for you appears to be the solution . The guys in the everglades & other boars use the same belt system .. as stated by those who replied .. the alternator can not move . Hope you find a a solution.. have a Merry christmas & a Happy New year..
serpentine belt & water pump belt coldfreshwater Engine 3 12-19-2012 06:03 AM
V-belt idler pulley ? belt rides backside JeepsAreBuilt Engine 4 05-09-2010 09:01 AM
V belt drive grapro Engine 0 09-09-2007 09:14 PM
going retro from serpentine belt system back to v-belt can i swap out the reverse ro motorhead1945 Engine 5 06-25-2007 06:56 PM
Swapping Gear Drive Out for Timing Chain or Belt Drive - Need Suggestions horvath Engine 4 05-24-2003 08:47 PM
